Maniphest T54506
Cloud repository - SSL Error
Closed, Resolved
Arto Kitula (akitula)
filip mond (vklidu)
Apr 3 2018, 3:20 PM
  • BF Blender
  • Blender Cloud
Brecht Van Lommel (brecht)
filip mond (vklidu)
Philipp Oeser (lichtwerk)
Sergey Sharybin (sergey)
Sybren A. Stüvel (sybren)
OS X 10.12.6, NVIDIA GeForce GTX 780M 4096 MB
Broken: 2.79.4
Worked: 2.79b
I can't login and open Blender Cloud Repository with daily builds.
I can reproduce it with today build (31f2a6755db) too.
Factory setting.
Behaviour is like this:
2.79.4 (daily build 31f2a6755db) I can't login.
2.79b (official) I can and I can also access repository
than if I'm logged in with official 2.79b
2.79.4 I see I'm logged
2.79.4 I can't still access cloud repository
Thank you for help
I had already discussion with Sybren, he asked me to run this commands (see screen).
After that he direct me to post it here.
(Left side official 2.79b / Right side daily 2.79.3 in that time)
Related Objects
Mentioned Here
rBcd5db907261e: Build Environment: updates for macOS.
T56329: MacOS benchmark client misses SSL module
rB31f2a6755db5: PyAPI: Add PyC_Tuple_Pack_F64 utility
filip mond (vklidu) created this task.Apr 3 2018, 3:20 PM
Christopher_Anderssarian added a project: Blender Cloud.Apr 3 2018, 10:47 PM
Arto Kitula (akitula) added subscribers: Sergey Sharybin (sergey), Arto Kitula (akitula).Apr 3 2018, 11:04 PM
On my macOS local build, this is working. Might be that buildbot isn't working as it should. svn problem or something like that. @Sergey Sharybin (sergey) ? Or anyone who has access to mac buildbot.
Sergey Sharybin (sergey) added a comment.Apr 4 2018, 9:16 AM
@Arto Kitula (akitula), can you reproduce the issue with buildbot builds on your machine?
Arto Kitula (akitula) added a comment.Apr 4 2018, 9:36 AM
@Sergey Sharybin (sergey) Actually just now realized that this happens because of the application translocator, the very reason we give releases on signed DMG.
@filip mond (vklidu) Could you try to start blender from Terminal ?
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Apr 4 2018, 9:45 AM
Buildbot should also be making signed dmg files I think, really the only difference with release builds should be the revision it's built from.
Sergey Sharybin (sergey) added a comment.Apr 4 2018, 9:46 AM
@Arto Kitula (akitula), do you think it will be smart idea and possible to sign buildbot binaries? Last time i've tried to sign in a headless mode, codesign gave me error code 0xffffffff...
Arto Kitula (akitula) added a comment.Apr 4 2018, 9:54 AM
@Sergey Sharybin (sergey) It is possible. I've got script that works, just needs some caring to do neat dmg. I'll push it when ready (next week latest).
Philipp Oeser (lichtwerk) assigned this task to Arto Kitula (akitula).Apr 4 2018, 11:43 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
@Arto Kitula (akitula) , assigning to you then?
filip mond (vklidu) added a comment.EditedApr 4 2018, 2:33 PM
@Arto Kitula (akitula) If you mentioned "translocation" issue - Do you mean "double docking" issue? Because I already moved blender out and in a directory, to "fix" that with mentioned build. But SSL error appeared before and after (double docking) anyway.
Running from Terminal - here is the output
if it helps in some way.
I also moved out all user files to run clear Blender and downloaded Blender Cloud addon to get all fresh :)
Arto Kitula (akitula) added a comment.Apr 4 2018, 4:26 PM
@Philipp Oeser (lichtwerk) yeah, that's ok.
@filip mond (vklidu) Yeah so this is not because of application translocation. Wondering why ssl module is not found. When I downloaded latest build from buildbot, it works.
What does following code give you?
import site
site.getsitepackages()
filip mond (vklidu) added a comment.Apr 4 2018, 5:16 PM
['/Users/filip/Downloads/blender-2.79.0-git20180403.31f2a6755db-x86_64/blender.app/Contents/Resources/2.79/python/lib/python3.6/site-packages']
Arto Kitula (akitula) added a comment.Apr 4 2018, 10:11 PM
That's just as it should. If you go that folder, does it have ssl.py ?
filip mond (vklidu) added a comment.EditedApr 5 2018, 10:12 AM
No.
In folder "site-packages" is only "easy_install.py"
Filtering with blender's file browser displayed only this file containing SSL.
urllib3/contrib/pyopenssl.py
Here is what inside "site-packages" folder
EDIT:
But "ssl.py" is in level up in "python3.6" folder as you can see on screen too.
That's probably you asked for, right?
Arto Kitula (akitula) lowered the priority of this task from 50 to 30.Apr 5 2018, 10:39 AM
Oops, that one level up is correct. Could you start the build with all debugging options on. And then just hit import ssl to python console and post the whole debug output.
Marking this as incomplete for now.
filip mond (vklidu) added a comment.Apr 5 2018, 11:26 AM
Thanks for reliance :) but what the hell is "start the build with all debugging options on"? :) Sorry, simple designer on this side of cable.
I would like to help you, but be a bit more descriptive for me, thank you. I will try my best.
Arto Kitula (akitula) added a comment.EditedApr 5 2018, 12:42 PM
No pressure =)
Let's do also factory startup so your preferences and some addons aren't affecting this:
./blender.app/Contents/MacOS/blender --factory-startup --debug-python
That is just for debugging python, --debug-all includes all debug messages. Let's start with --debug-python for now.
filip mond (vklidu) added a comment.Apr 5 2018, 2:48 PM
Here it is, just a note when I started now from terminal I was still logged in (by official 2.79b version) and I tried to open cloud from image editor, or should I log out first?
Arto Kitula (akitula) added a comment.Apr 5 2018, 3:56 PM
What if you move directory /Users/filip/Library/Application Support/Blender/2.79/ away and start blender again, and install the latest cloud addon?
filip mond (vklidu) added a comment.EditedApr 5 2018, 6:01 PM
That's exactly what I did yesterday.
  • downloaded daily build
  • moved whole folder 2.79 from Application Support
  • downloaded addon available from cloud, installed
Same error.
Should I do it again for you to get generated console output?
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Jun 20 2018, 4:13 PM
Sybren A. Stüvel (sybren) added a subscriber: Sybren A. Stüvel (sybren).Aug 18 2018, 11:28 PM
We have a report (T56329) with the same issue in the Benchmark Client, so it's not just buildbot-builds.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Sep 11 2018, 8:47 AM
This will be fixed now in the latest daily builds after rBcd5db907261e: Build Environment: updates for macOS..
