Maniphest T54650
Multi-Object-Mode: Pose Tools
Closed, Resolved
Joshua Leung (aligorith)
Apr 16 2018, 12:58 PM
  • Code Quest
Dalai Felinto (dfelinto)
Notes about notation
  • Excluded from Multi-Object Editing - Everything in (parentheses)
  • Priority items (i.e. for Spring migration) - Everything in bold
Notes about approach (25/5)
Talking with the animators here in the studio, it seems that most of the time, animators don't actually want most tools to work with "full" multi-object posing behaviour. So, what we might do here instead is that by default, pose operators still work in the old (single active object) way, with just a few specific exceptions added on a case-by-case basis (as/when desired by animators). Examples here include mouse select tools and basic loc/rot/scale transform tools. Many other tools may be best left as single-object for now.
pose_edit.c
  • POSE_OT_paths_clear rB478446e3a45c5eff7aed238b92e5d3d7cf671c7a
  • POSE_OT_paths_calculate rB478446e3a45c5eff7aed238b92e5d3d7cf671c7a
  • POSE_OT_paths_update rB478446e3a45c5eff7aed238b92e5d3d7cf671c7a
  • POSE_OT_flip_names
  • POSE_OT_autoside_names rBc7bbcfe95444e730eacf655fd982f5091d5e2ff6
  • POSE_OT_rotation_mode_set rB3b9b6a80ba6311281bb90e2a2e63a8c34a0b575d
  • ARMATURE_OT_armature_layers rB3a8b56ce24c9228a885d3c44f4c22d90be04ae4c
  • POSE_OT_bone_layers rBbb7f4f5714430beda44403f0bd75c368e8f86a39
  • POSE_OT_hide rBc9d1082a2c17162ea6d23415e3560dabfc6e22e1
  • POSE_OT_reveal rBc9d1082a2c17162ea6d23415e3560dabfc6e22e1
  • POSE_OT_quaternions_flip rB7560aabf71dd4c7687ff0110e722287d66358bbd
pose_group.c
Note: With these ones, we made the decision to only allow supporting the "active object" as displayed in the UI (where these operators appear). As a result, multi-object editing doesn't actually function with these operators. But also, no further changes are required
  • (POSE_OT_group_add)
  • (POSE_OT_group_remove)
  • POSE_OT_group_unassign
  • POSE_OT_group_assign
  • (POSE_OT_group_move)
  • (POSE_OT_group_sort)
  • POSE_OT_group_select
  • POSE_OT_group_deselect
pose_lib.c
  • Most operators here are fine, as they don't use the context iterators to loop over bones, and it doesn't make sense to apply Pose Libraries (defined for a single armature) across multiple selected armatures.
  • The one exception here is the ~~POSELIB_OT_pose_add~~ operator, as it needs to use the Whole Character (selected) KeyingSet to determine what bones get added to the library. The one problem with this though is that this keyingset uses the context.selected_pose_bones iterator, which includes bones from multiple active armatures. We'll need a solution here to allow restricting keyingsets without also losing all filtering capabilities in the iterator (i.e. we'd lose the name-filtering used to determine what bones should/shouldn't get included). (done rBc462c43c1a05).
  • POSELIB_OT_action_sanitize
  • POSELIB_OT_apply_pose
  • POSELIB_OT_browse_interactive
  • POSELIB_OT_new
  • POSELIB_OT_pose_move
  • POSELIB_OT_pose_remove
  • POSELIB_OT_pose_rename
  • POSELIB_OT_unlink
pose_select.c
  • VIEW3D_OT_select_border
  • VIEW3D_OT_select_circle
  • POSE_OT_select_all
  • POSE_OT_select_mirror
  • POSE_OT_select_constraint_target rB374a8b9da50bdc3c40cef9394065d5394bb91f33
  • POSE_OT_select_linked
  • POSE_OT_select_hierarchy rBd95bb08f395ace3fdfed71058658b7acef458ded
  • POSE_OT_select_groupedrBcaad2d7528bc38934a90bb30b417068b71076bcd
pose_transform.c
  • POSE_OT_visual_transform_apply rB4376bb64054cb8de0b71f85d4faa832d4ec736cd
  • POSE_OT_armature_apply
  • POSE_OT_copy - [To be ported by @Joshua Leung (aligorith)] (*1)
  • POSE_OT_paste - [To be ported by @Joshua Leung (aligorith)] (*1)
  • POSE_OT_transforms_clear rBe0478ae92fbefbc648bfb5a5f8370a53af1c6679
    • POSE_OT_loc_clear
    • POSE_OT_rot_clear
    • POSE_OT_scale_clear
  • POSE_OT_user_transforms_clear rB4529192157135bfdc5f5fb48c798f7b205f25570
(*1) Copy/Paste - These currently don't have any problems working with multi-objects (i..e you don't get wrong bones getting copied/pasted). The only problem is that you can only from and paste to whatever armature is active at the time the operator is invoked. (So, you can copy a pose from one armature and paste it into another without leaving pose mode, as long as both objects are in posemode). So, currently marking these as working.
pose_slide.c
  • NLA_OT_bake rBf10bc11061cf rB39ad5c3ef1ea (though undo doesn't seem to be working well).
  • POSE_OT_breakdown rB3c61efcf206dcce904570baef1d5e209415d0ea9
  • POSE_OT_relax rB3c61efcf206dcce904570baef1d5e209415d0ea9
  • POSE_OT_push rB3c61efcf206dcce904570baef1d5e209415d0ea9
  • POSE_OT_propagate rB3c61efcf206dcce904570baef1d5e209415d0ea9
Others
  • POSE_OT_ik_clearrBf3153f1c7f57c054ecc7d0f986c6afc1d70ffb7d
  • POSE_OT_ik_add rB7baa8d2e8f07328fbb187e82f477e56950c25c46
  • POSE_OT_constraints_clear rB647218af07dab9d3abd9c3a058701ea36c87930d
  • POSE_OT_constraints_copy rB418c16bd3b799a95f9dc4d458213c60fba42626c
  • POSE_OT_constraint_add_with_targets rB7baa8d2e8f07328fbb187e82f477e56950c25c46
  • POSE_OT_select_parent rBdcf1210c44cb1e46bf387f326c5ee9daa2a53004
Revisions and Commits
Related Objects
StatusSubtypeAssignedTask
ConfirmedTO DONone
ResolvedJoshua Leung (aligorith)
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Normal.Apr 16 2018, 12:58 PM
Campbell Barton (campbellbarton) created this task.
Campbell Barton (campbellbarton) updated the task description.Apr 16 2018, 2:02 PM
Campbell Barton (campbellbarton) updated the task description.Apr 17 2018, 11:27 AM
Campbell Barton (campbellbarton) updated the task description.Apr 18 2018, 7:03 PM
Campbell Barton (campbellbarton) updated the task description.Apr 18 2018, 7:13 PM
Joshua Leung (aligorith) moved this task from Tasks to Short Term Backlog on the Code Quest board.Apr 23 2018, 12:48 PM
Joshua Leung (aligorith) added a subscriber: Joshua Leung (aligorith).
Joshua Leung (aligorith) claimed this task.Apr 23 2018, 1:14 PM
Joshua Leung (aligorith) updated the task description.
Joshua Leung (aligorith) updated the task description.Apr 23 2018, 2:24 PM
Joshua Leung (aligorith) updated the task description.Apr 24 2018, 2:33 PM
Joshua Leung (aligorith) updated the task description.Apr 24 2018, 2:58 PM
Joshua Leung (aligorith) updated the task description.Apr 24 2018, 3:03 PM
Joshua Leung (aligorith) moved this task from Short Term Backlog to Doing on the Code Quest board.Apr 25 2018, 10:55 AM
Joshua Leung (aligorith) updated the task description.Apr 30 2018, 4:46 PM
Joshua Leung (aligorith) updated the task description.Apr 30 2018, 6:25 PM
Campbell Barton (campbellbarton) updated the task description.May 1 2018, 2:29 PM
Joshua Leung (aligorith) updated the task description.May 1 2018, 2:32 PM
Joshua Leung (aligorith) updated the task description.May 1 2018, 4:58 PM
Joshua Leung (aligorith) updated the task description.May 2 2018, 6:30 PM
Joshua Leung (aligorith) updated the task description.May 3 2018, 6:08 PM
Dalai Felinto (dfelinto) updated the task description.May 9 2018, 12:54 PM
Dalai Felinto (dfelinto) updated the task description.May 14 2018, 2:30 PM
Joshua Leung (aligorith) updated the task description.May 15 2018, 2:41 PM
Joshua Leung (aligorith) updated the task description.May 28 2018, 8:28 PM
Brecht Van Lommel (brecht) moved this task from Doing to Tasks on the Code Quest board.Aug 13 2018, 11:49 AM
Dalai Felinto (dfelinto) updated the task description.Oct 12 2018, 8:29 PM
Dalai Felinto (dfelinto) updated the task description.Oct 12 2018, 10:31 PM
Dalai Felinto (dfelinto) mentioned this in rB3ffc2a8330fd: Multi-Objects: POSE_OT_paths_*.Oct 12 2018, 10:45 PM
Dalai Felinto (dfelinto) updated the task description.Oct 12 2018, 10:45 PM
Dalai Felinto (dfelinto) updated the task description.Oct 13 2018, 12:41 AM
Dalai Felinto (dfelinto) updated the task description.Oct 13 2018, 12:54 AM
Dalai Felinto (dfelinto) updated the task description.Oct 13 2018, 1:07 AM
Dalai Felinto (dfelinto) updated the task description.Oct 17 2018, 12:46 AM
Dalai Felinto (dfelinto) updated the task description.Oct 17 2018, 2:11 AM
Dalai Felinto (dfelinto) updated the task description.Oct 19 2018, 2:43 PM
Dalai Felinto (dfelinto) updated the task description.Oct 19 2018, 8:48 PM
Dalai Felinto (dfelinto) updated the task description.Oct 19 2018, 9:54 PM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Oct 20 2018, 2:23 AM
Dalai Felinto (dfelinto) added a subscriber: Dalai Felinto (dfelinto).
You are hereby closed.
Dalai Felinto (dfelinto) changed the task status from Resolved to Unknown Status.Oct 20 2018, 2:24 AM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Oct 20 2018, 2:34 AM
