Maniphest T54667
Make sure dependency graph does not have known regressions
Closed, Resolved
Sergey Sharybin (sergey)
Apr 16 2018, 5:57 PM
  • Code Quest
  • Dependency Graph
Make sure there are no known regressions in dependency graph with existing tests. Will make us more sure that depsgraph is ready for the CoW operators transition.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to 50.Apr 16 2018, 5:57 PM
Sergey Sharybin (sergey) created this task.
Sergey Sharybin (sergey) added a comment.Apr 17 2018, 12:16 PM
Went over regression tests and some Spring production files. Think there should be no stoppers from DEG to start porting operators.
While doing that, we should keep T54688 and T54689 in mind, just so we are not confused that some operator is broken.
Sergey Sharybin (sergey) lowered the priority of this task from 50 to Normal.Apr 17 2018, 12:16 PM
Sergey Sharybin (sergey) moved this task from Doing to Reviewing on the Code Quest board.
Dalai Felinto (dfelinto) moved this task from Reviewing to Done on the Code Quest board.Apr 18 2018, 12:26 PM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Apr 23 2018, 1:20 PM
