Maniphest T54776
Orphaned Controls
Closed, ResolvedDESIGN
William Reynish (billreynish)
Apr 23 2018, 6:51 PM
  • Code Quest
In Blender 2.8, we want to remove all settings and options from the toolbar, and just present a list of tools. The tool settings will be moved to the Top Bar, but there are still some settings left that need a new home. Here's a list:
Object Mode
History Panel (Undo, Redo, History, Undo History Repeat Last)
These we can simply remove. We may want to later create a real History Editor for better overview of the history.
Create tab (for adding things into the scene)
All this is also in the Add menu. We can just remove it.
Relations tab
These are duplicated in menus. We can remove this completely.
Animation tab
These are duplicated in menus and in the properties, for motion paths. We can safely remove this tab
Rigid Body Tools
These commands have always been odd. They are so specific to one feature. We can move them to the 'Commands' tab/menu in the toolbar for now.
Grease Pencil tools
Since this applies to all modes, and we want to make Grease Pencil act as an active tool, we want to keep Grease Pencil. I think it makes sense to keep them in their own 'tab', even if it's represented as a menu at the top.
Grease Pencil tool settings
These will be displayed in the Top Bar when you have the relevant Grease Pencil tool selected.
Edit Mode
Mesh Options
We could add an entry on the right side of the top bar called 'Options'. This opens a popover with these settings inside.
Sculpt Mode
Brush panels
These go in the Top Bar. We can also put them into a new Tool Settings Editor.
Weight Paint Mode
Weight Tools
These we can put into the Commands tab/menu
Weight Paint Options
Pose Mode/Armature Edit Mode
Options
  • Auto IK
  • X-Ray Mirror
Related Objects
StatusSubtypeAssignedTask
ConfirmedDESIGNCampbell Barton (campbellbarton)
ResolvedDESIGNWilliam Reynish (billreynish)
William Reynish (billreynish) lowered the priority of this task from 90 to Normal.Apr 23 2018, 6:51 PM
William Reynish (billreynish) created this task.
William Reynish (billreynish) updated the task description.Apr 23 2018, 6:57 PM
William Reynish (billreynish) updated the task description.Apr 23 2018, 7:09 PM
Joshua Leung (aligorith) updated the task description.Apr 24 2018, 11:23 AM
William Reynish (billreynish) moved this task from Doing to Reviewing on the Code Quest board.Apr 25 2018, 7:29 PM
William Reynish (billreynish) added a parent task: T54844: Code Quest Tool System (Parent Task).Apr 26 2018, 7:05 PM
Dalai Felinto (dfelinto) moved this task from Reviewing to Done on the Code Quest board.Apr 30 2018, 10:06 AM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Apr 30 2018, 10:09 AM
