Maniphest T54818
COW Operators: Physics
Closed, ArchivedTO DO
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Apr 25 2018, 2:34 PM
  • Code Quest
  • Dependency Graph
Instructions
See T54810 for details
editors/physics module
Rigidbody Tools
  • RIGIDBODY_OT_object_add
  • RIGIDBODY_OT_object_remove
  • RIGIDBODY_OT_objects_add
  • RIGIDBODY_OT_objects_remove
  • RIGIDBODY_OT_shape_change
  • RIGIDBODY_OT_mass_calculate
  • RIGIDBODY_OT_constraint_add
  • RIGIDBODY_OT_constraint_remove
  • RIGIDBODY_OT_world_add
  • RIGIDBODY_OT_world_remove
  • RIGIDBODY_OT_world_export
Caches and Baking
  • FLUID_OT_bake
  • PTCACHE_OT_bake_all
  • PTCACHE_OT_free_bake_all
  • PTCACHE_OT_bake
  • PTCACHE_OT_bake_from_cache
  • PTCACHE_OT_add
  • PTCACHE_OT_remove
Dynamic Paint
  • DPAINT_OT_bake
  • DPAINT_OT_surface_slot_add
  • DPAINT_OT_surface_slot_remove
  • DPAINT_OT_type_toggle
  • DPAINT_OT_output_toggle
Particles Edit Mode
(Note: Depends on having working particles/particle edit mode first)
  • PARTICLE_OT_select_all
  • PARTICLE_OT_select_roots
  • PARTICLE_OT_select_tips
  • PARTICLE_OT_select_random
  • PARTICLE_OT_select_linked
  • PARTICLE_OT_select_less
  • PARTICLE_OT_select_more
  • PARTICLE_OT_hide
  • PARTICLE_OT_reveal
  • PARTICLE_OT_rekey
  • PARTICLE_OT_subdivide
  • PARTICLE_OT_remove_doubles
  • PARTICLE_OT_weight_set
  • PARTICLE_OT_delete
  • PARTICLE_OT_mirror
  • PARTICLE_OT_brush_edit
  • PARTICLE_OT_shape_cut
  • PARTICLE_OT_particle_edit_toggle
  • PARTICLE_OT_edited_clear
  • PARTICLE_OT_unify_length
Particle System UI
  • OBJECT_OT_particle_system_add
  • OBJECT_OT_particle_system_remove
  • PARTICLE_OT_new
  • PARTICLE_OT_new_target
  • PARTICLE_OT_target_remove
  • PARTICLE_OT_target_move_up
  • PARTICLE_OT_target_move_down
  • PARTICLE_OT_connect_hair
  • PARTICLE_OT_disconnect_hair
  • PARTICLE_OT_copy_particle_systems
  • PARTICLE_OT_duplicate_particle_system
  • PARTICLE_OT_dupliob_copy
  • PARTICLE_OT_dupliob_remove
  • PARTICLE_OT_dupliob_move_up
  • PARTICLE_OT_dupliob_move_down
Boids (Particle System UI)
  • BOID_OT_rule_add
  • BOID_OT_rule_del
  • BOID_OT_rule_move_up
  • BOID_OT_rule_move_down
  • BOID_OT_state_add
  • BOID_OT_state_del
  • BOID_OT_state_move_up
  • BOID_OT_state_move_down
Revisions and Commits
Related Objects
StatusSubtypeAssignedTask
ArchivedTO DOJoshua Leung (aligorith)
ArchivedTO DOBrecht Van Lommel (brecht)
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 2:34 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) added a parent task: T54810: Port operators to use COW (Parent Task).
Joshua Leung (aligorith) updated the task description.Apr 25 2018, 4:21 PM
Joshua Leung (aligorith) moved this task from Tasks to Doing on the Code Quest board.May 9 2018, 12:59 PM
Joshua Leung (aligorith) added a revision: D3193: COW updates for rigid body operators (T54810)..
Brecht Van Lommel (brecht) moved this task from Doing to Tasks on the Code Quest board.Aug 13 2018, 11:49 AM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:43 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
