Maniphest T54823
COW Operators: Movie Clip Editor
Closed, ArchivedTO DO
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Apr 25 2018, 2:46 PM
  • Code Quest
  • Dependency Graph
Sergey Sharybin (sergey)
Instructions
See T54810 for details
editors/space_clip module
  • CLIP_OT_open
  • CLIP_OT_reload
  • CLIP_OT_view_pan
  • CLIP_OT_view_zoom
  • CLIP_OT_view_zoom_in
  • CLIP_OT_view_zoom_out
  • CLIP_OT_view_zoom_ratio
  • CLIP_OT_view_all
  • CLIP_OT_view_selected
  • CLIP_OT_change_frame
  • CLIP_OT_rebuild_proxy
  • CLIP_OT_mode_set
  • CLIP_OT_view_ndof
  • CLIP_OT_prefetch
  • CLIP_OT_set_scene_frames
  • CLIP_OT_cursor_set
  • CLIP_OT_tools
  • CLIP_OT_properties
  • CLIP_OT_frame_jump
  • CLIP_OT_set_center_principal
  • CLIP_OT_select
  • CLIP_OT_select_all
  • CLIP_OT_select_border
  • CLIP_OT_select_lasso
  • CLIP_OT_select_circle
  • CLIP_OT_select_grouped
  • CLIP_OT_add_marker
  • CLIP_OT_add_marker_at_click
  • CLIP_OT_slide_marker
  • CLIP_OT_delete_track
  • CLIP_OT_delete_marker
  • CLIP_OT_track_markers
  • CLIP_OT_refine_markers
  • CLIP_OT_solve_camera
  • CLIP_OT_clear_solution
  • CLIP_OT_disable_markers
  • CLIP_OT_hide_tracks
  • CLIP_OT_hide_tracks_clear
  • CLIP_OT_lock_tracks
  • CLIP_OT_set_solver_keyframe
  • CLIP_OT_set_origin
  • CLIP_OT_set_plane
  • CLIP_OT_set_axis
  • CLIP_OT_set_scale
  • CLIP_OT_set_solution_scale
  • CLIP_OT_apply_solution_scale
  • CLIP_OT_detect_features
  • CLIP_OT_stabilize_2d_add
  • CLIP_OT_stabilize_2d_remove
  • CLIP_OT_stabilize_2d_select
  • CLIP_OT_stabilize_2d_rotation_add
  • CLIP_OT_stabilize_2d_rotation_remove
  • CLIP_OT_stabilize_2d_rotation_select
  • CLIP_OT_clear_track_path
  • CLIP_OT_join_tracks
  • CLIP_OT_track_copy_color
  • CLIP_OT_clean_tracks
  • CLIP_OT_tracking_object_new
  • CLIP_OT_tracking_object_remove
  • CLIP_OT_copy_tracks
  • CLIP_OT_paste_tracks
  • CLIP_OT_create_plane_track
  • CLIP_OT_slide_plane_marker
  • CLIP_OT_keyframe_insert
  • CLIP_OT_keyframe_delete
  • CLIP_OT_graph_select
  • CLIP_OT_graph_select_border
  • CLIP_OT_graph_select_all_markers
  • CLIP_OT_graph_delete_curve
  • CLIP_OT_graph_delete_knot
  • CLIP_OT_graph_view_all
  • CLIP_OT_graph_center_current_frame
  • CLIP_OT_graph_disable_markers
  • CLIP_OT_dopesheet_select_channel
  • CLIP_OT_dopesheet_view_all
Related Objects
StatusSubtypeAssignedTask
ArchivedTO DOJoshua Leung (aligorith)
ArchivedTO DOBrecht Van Lommel (brecht)
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 2:46 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) removed Joshua Leung (aligorith) as the assignee of this task.Apr 25 2018, 2:48 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:40 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
