Instructions
See T54810 for details
Note: Most of these are UI operators, but they may still require some careful checking
editors/space_node module
NODE_OT_propertiesNODE_OT_toolbar- NODE_OT_select
- NODE_OT_select_all
- NODE_OT_select_linked_to
- NODE_OT_select_linked_from
- NODE_OT_select_border
- NODE_OT_select_circle
- NODE_OT_select_lasso
- NODE_OT_select_grouped
- NODE_OT_select_same_type_step
- NODE_OT_find_node
- NODE_OT_view_all
- NODE_OT_view_selected
- NODE_OT_mute_toggle
- NODE_OT_hide_toggle
- NODE_OT_preview_toggle
- NODE_OT_options_toggle
- NODE_OT_hide_socket_toggle
- NODE_OT_node_copy_color
- NODE_OT_duplicate
- NODE_OT_delete
- NODE_OT_delete_reconnect
- NODE_OT_resize
- NODE_OT_link
- NODE_OT_link_make
- NODE_OT_links_cut
- NODE_OT_links_detach
- NODE_OT_add_reroute
- NODE_OT_group_make
- NODE_OT_group_insert
- NODE_OT_group_ungroup
- NODE_OT_group_separate
- NODE_OT_group_edit
- NODE_OT_link_viewer
- NODE_OT_insert_offset
- NODE_OT_read_viewlayers
- NODE_OT_render_changed
- NODE_OT_backimage_move
- NODE_OT_backimage_zoom
- NODE_OT_backimage_fit
- NODE_OT_backimage_sample
- NODE_OT_add_file
- NODE_OT_add_mask
- NODE_OT_new_node_tree
- NODE_OT_output_file_add_socket
- NODE_OT_output_file_remove_active_socket
- NODE_OT_output_file_move_active_socket
- NODE_OT_parent_set
- NODE_OT_join
- NODE_OT_attach
- NODE_OT_detach
- NODE_OT_clipboard_copy
- NODE_OT_clipboard_paste
- NODE_OT_shader_script_update
- NODE_OT_viewer_border
- NODE_OT_clear_viewer_border
- NODE_OT_switch_view_update
- NODE_OT_tree_socket_add
- NODE_OT_tree_socket_remove
- NODE_OT_tree_socket_move
