Maniphest T54828
COW Operators: Sequencer
Closed, ArchivedTO DO
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Apr 25 2018, 2:55 PM
  • Code Quest
  • Dependency Graph
Sergey Sharybin (sergey)
Instructions
See T54810 for details
editors/space_sequencer module
  • SEQUENCER_OT_cut
  • SEQUENCER_OT_slip
  • SEQUENCER_OT_mute
  • SEQUENCER_OT_unmute
  • SEQUENCER_OT_lock
  • SEQUENCER_OT_unlock
  • SEQUENCER_OT_reload
  • SEQUENCER_OT_refresh_all
  • SEQUENCER_OT_reassign_inputs
  • SEQUENCER_OT_swap_inputs
  • SEQUENCER_OT_duplicate
  • SEQUENCER_OT_delete
  • SEQUENCER_OT_offset_clear
  • SEQUENCER_OT_images_separate
  • SEQUENCER_OT_meta_toggle
  • SEQUENCER_OT_meta_make
  • SEQUENCER_OT_meta_separate
  • SEQUENCER_OT_gap_remove
  • SEQUENCER_OT_gap_insert
  • SEQUENCER_OT_snap
  • SEQUENCER_OT_strip_jump
  • SEQUENCER_OT_swap
  • SEQUENCER_OT_swap_data
  • SEQUENCER_OT_rendersize
  • SEQUENCER_OT_export_subtitles
  • SEQUENCER_OT_copy
  • SEQUENCER_OT_paste
  • SEQUENCER_OT_view_all
  • SEQUENCER_OT_view_selected
  • SEQUENCER_OT_view_frame
  • SEQUENCER_OT_view_all_preview
  • SEQUENCER_OT_view_toggle
  • SEQUENCER_OT_view_zoom_ratio
  • SEQUENCER_OT_view_ghost_border
  • SEQUENCER_OT_rebuild_proxy
  • SEQUENCER_OT_enable_proxies
  • SEQUENCER_OT_change_effect_input
  • SEQUENCER_OT_change_effect_type
  • SEQUENCER_OT_change_path
  • SEQUENCER_OT_select_all
  • SEQUENCER_OT_select_more
  • SEQUENCER_OT_select_less
  • SEQUENCER_OT_select_linked_pick
  • SEQUENCER_OT_select_handles
  • SEQUENCER_OT_select_active_side
  • SEQUENCER_OT_select_border
  • SEQUENCER_OT_select_grouped
  • SEQUENCER_OT_scene_strip_add
  • SEQUENCER_OT_movieclip_strip_add
  • SEQUENCER_OT_mask_strip_add
  • SEQUENCER_OT_movie_strip_add
  • SEQUENCER_OT_sound_strip_add
  • SEQUENCER_OT_image_strip_add
  • SEQUENCER_OT_effect_strip_add
  • SEQUENCER_OT_properties
  • SEQUENCER_OT_strip_modifier_add
  • SEQUENCER_OT_strip_modifier_remove
  • SEQUENCER_OT_strip_modifier_move
  • SEQUENCER_OT_strip_modifier_copy
  • SEQUENCER_OT_sample
Related Objects
StatusSubtypeAssignedTask
ArchivedTO DOJoshua Leung (aligorith)
ArchivedTO DOBrecht Van Lommel (brecht)
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 2:55 PM
Joshua Leung (aligorith) created this task.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:40 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
