Maniphest T54831
COW Operators: Transform
Closed, ArchivedTO DO
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Apr 25 2018, 3:24 PM
  • Code Quest
  • Dependency Graph
Sergey Sharybin (sergey)
Tuomo Keskitalo (tkeskita)
editors/transform module
What to do
Each of the conversion functions for different types of data in transform_conversions.c need to be checked and/or converted to use evaluated data. The changes needed are not always immediately intuitive: In most cases, you need to read current values from evaluated copy (since animation is applied there), then allow writing (by setting pointers in the td structs) to the original data.
Example Commits
  • rB0492e56fece3e0c7d7d43a8d06b393bc9f911fa2 - Pose bones
  • rB988a14aa143e82be3c50c3df82c860fbdf3207b0 - Object transforms
Operators
  • TRANSFORM_OT_transform
    • Transform Tools
    • Modes
      • Object Mode
      • Pose Mode
      • Edit Mode: Mesh
      • Edit Mode: Armature
      • Edit Mode: Curves
      • Edit Mode: Grease Pencil (Todo for GP Branch only)
      • TexSpace
  • TRANSFORM_OT_select_orientation
  • TRANSFORM_OT_create_orientation
  • TRANSFORM_OT_delete_orientation
Related Objects
StatusSubtypeAssignedTask
ArchivedTO DOJoshua Leung (aligorith)
ArchivedTO DOBrecht Van Lommel (brecht)
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 3:24 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) updated the task description.May 2 2018, 11:09 AM
Joshua Leung (aligorith) triaged this task as 90 priority.May 25 2018, 4:10 PM
Joshua Leung (aligorith) moved this task from Tasks to Spring Bugs on the Code Quest board.
Joshua Leung (aligorith) updated the task description.May 25 2018, 4:41 PM
Tuomo Keskitalo (tkeskita) added a subscriber: Tuomo Keskitalo (tkeskita).May 26 2018, 4:12 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.Sep 28 2018, 3:58 PM
Brecht Van Lommel (brecht) moved this task from Spring Bugs to Tasks on the Code Quest board.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:41 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
