Maniphest T54832
COW Operators: User Interface Stuff
Closed, ArchivedTO DO
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Apr 25 2018, 3:30 PM
  • Code Quest
  • Dependency Graph
Sergey Sharybin (sergey)
Instructions
See T54810 for details
Most of these should only require minor tweaks. But, still need checking...
editors/interface module
Maybe?
  • UI_OT_reset_default_button - Depends on the property used. It "works" when everything is configured correctly with the property being fixed. (e.g. d9c5a35587d)
  • UI_OT_unset_property_button
  • UI_OT_use_property_button
  • UI_OT_unuse_property_button
  • UI_OT_override_type_set_button
  • UI_OT_override_remove_button
  • UI_OT_copy_to_selected_button
  • UI_OT_reports_to_textblock
  • UI_OT_editsource - Mostly working. Not working so well though due to lack of info editor
  • UI_OT_edittranslation_init
  • UI_OT_reloadtranslation
Definitely
  • UI_OT_drop_color - rB3c1483cf1eb
  • UI_OT_eyedropper_color
  • UI_OT_eyedropper_colorband
  • UI_OT_eyedropper_colorband_point
  • UI_OT_eyedropper_id
  • UI_OT_eyedropper_depth
  • UI_OT_eyedropper_driver
editors/scene module
  • SCENE_OT_new
  • SCENE_OT_delete
editors/screen
  • SCREEN_OT_frame_offset - CRASHING on Shift-UpArrow wtih Dweebs file (with 26d87bd57795c39138ba982cc06a20b466eddb2c, in subsurf code)
  • SCREEN_OT_frame_jump
  • SCREEN_OT_keyframe_jump
  • SCREEN_OT_marker_jump
  • SCREEN_OT_animation_step
  • SCREEN_OT_animation_play
  • SCREEN_OT_animation_cancel
  • SCREEN_OT_repeat_last
  • SCREEN_OT_repeat_history
  • SCREEN_OT_redo_last
  • SCREEN_OT_region_blend
  • SCREEN_OT_screenshot
  • SCREEN_OT_screencast
  • SCREEN_OT_space_context_cycle
  • SCREEN_OT_new
  • SCREEN_OT_delete
editors/screen/undo.c
  • ED_OT_undo
  • ED_OT_undo_push
  • ED_OT_redo
  • ED_OT_undo_redo
  • ED_OT_undo_history
  • ED_OT_flush_edits
workspace_edit.c (4)
Note: Most of these should be fine and well tested by now
  • WORKSPACE_OT_workspace_duplicate
  • WORKSPACE_OT_workspace_delete
  • WORKSPACE_OT_workspace_add_menu
  • WORKSPACE_OT_append_activate
script_ops.c (3)
Note: These should be fine
  • SCRIPT_OT_python_file_run
  • SCRIPT_OT_reload
  • SCRIPT_OT_autoexec_warn_clear
Related Objects
StatusSubtypeAssignedTask
ArchivedTO DOJoshua Leung (aligorith)
ArchivedTO DOBrecht Van Lommel (brecht)
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Apr 25 2018, 3:30 PM
Joshua Leung (aligorith) created this task.
Joshua Leung (aligorith) updated the task description.
Joshua Leung (aligorith) updated the task description.May 4 2018, 5:21 PM
Joshua Leung (aligorith) updated the task description.May 4 2018, 5:33 PM
Joshua Leung (aligorith) updated the task description.May 4 2018, 6:38 PM
Joshua Leung (aligorith) moved this task from Tasks to Doing on the Code Quest board.
Inês Almeida (brita_) updated the task description.May 28 2018, 11:10 PM
Brecht Van Lommel (brecht) moved this task from Doing to Tasks on the Code Quest board.Aug 13 2018, 11:49 AM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 19 2018, 12:42 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Most operators appear to be working, and we will use bug tracker to handle remaining issues.
