Maniphest T54953
Workbench: Use OCIO for display color management
Closed, ResolvedTO DO
Jeroen Bakker (jbakker)
May 4 2018, 3:55 PM
  • Code Quest
  • render to offscreen buffer
  • screen buffer should be float based (10b/half)
  • bind default color only fb
  • call void DRW_transform_to_display(struct GPUTexture *tex);
  • remove current conversion from composite pass
Related Objects
StatusSubtypeAssignedTask
ResolvedTO DOJeroen Bakker (jbakker)
Jeroen Bakker (jbakker) renamed this task from Workbench: Integrate OCIO for color management to Workbench: Use OCIO for color management.May 4 2018, 3:55 PM
Jeroen Bakker (jbakker) renamed this task from Workbench: Use OCIO for color management to Workbench: Use OCIO for display color management.
Jeroen Bakker (jbakker) created this task.
Jeroen Bakker (jbakker) updated the task description.May 4 2018, 3:57 PM
Jeroen Bakker (jbakker) mentioned this in rBd85fd8feeb1b: T54953: Use OCIO for display color management.May 4 2018, 4:32 PM
Jeroen Bakker (jbakker) moved this task from Tasks to Reviewing on the Code Quest board.May 4 2018, 4:33 PM
Jeroen Bakker (jbakker) added a parent task: T54907: Workbench (parent task).May 4 2018, 4:49 PM
Dalai Felinto (dfelinto) moved this task from Reviewing to Done on the Code Quest board.May 7 2018, 9:23 AM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.May 7 2018, 9:25 AM
