Maniphest T55139
COW problem: auto keying while animation is playing is broken
Closed, Resolved
Joshua Leung (aligorith)
Inês Almeida (brita_)
May 21 2018, 4:45 PM
  • BF Blender
Brecht Van Lommel (brecht)
2.8 0e9605f44d2 (Monday 21May) with --enable-copy-on-write
  1. Open default .blend file
  2. Turn on auto-keying. Play.
  3. Move the cube -> keys are set but not correctly. the cube doesn't move.
Check also special cases such as:
  1. From camera view (numpad 0), set View > Lock Camera to View
  3. Rotate the view (middle mouse) -> same problem as above, but different code path. Check ED_view3d_camera_lock_autokey
Related Objects
Mentioned In
T54829: COW Operators: 3D View
Mentioned Here
rB0e9605f44d26: Merge branch 'master' into blender2.8
Inês Almeida (brita_) assigned this task to Joshua Leung (aligorith).May 21 2018, 4:45 PM
Inês Almeida (brita_) lowered the priority of this task from 90 to 50.
Inês Almeida (brita_) created this task.
Inês Almeida (brita_) mentioned this in T54829: COW Operators: 3D View.May 21 2018, 9:06 PM
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed BF Blender: 2.8.Dec 11 2018, 3:09 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Mar 18 2019, 7:45 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
This appears to be solved in latest master.
