Maniphest T55456
Polish Edit mode Drawing
Closed, ArchivedTO DO
Jeroen Bakker (jbakker)
Jun 12 2018, 4:51 PM
  • Code Quest
babajan (johnsyed)
Bastien Montagne (mont29)
Tokens
"Love" token, awarded by johnsyed.
  • dim edges in Vertex, Face select mode
  • only show facedots when in use_occlude_geometry
  • better masking for selected faces
  • theme option:
    • Color of active element in active mode
    • Color of selected element in active mode
    • Color of active element not in active mode
    • Color of selected element not in active mode
Only for edges
  • Color of element in active mode (black)
  • Color of element not in active mode (grey)
Also facedot.
(alpha only for faces)
Original
Face Selection Color with stips
Face Selection Color with diagonal stripes
Face Selection Color with diagonal grid
Outline
Outline (thicker)
Related Objects
Mentioned In
rB9d34a9d7e59d: DRW: add back edge highlighting for active face drawing
T54940: 2.8: Code-Quest (Maintainer decisions pending)
rB277d90127417: T55456 EditMeshMode
rB2e23385c3572: T55456: EditDrawMode
rB645c91882530: T55456: EditDrawMode
rBb8015ece51c2: Revert "T55456: EditDrawMode"
rBda6ed54569d0: T55456: EditDrawMode
rB23c24cead582: T55456: EditMode Drawing
Jeroen Bakker (jbakker) created this task.Jun 12 2018, 4:51 PM
babajan (johnsyed) awarded a token.Jun 12 2018, 8:26 PM
Jeroen Bakker (jbakker) mentioned this in rB23c24cead582: T55456: EditMode Drawing.Jun 13 2018, 12:40 PM
Jeroen Bakker (jbakker) updated the task description.Jun 13 2018, 1:00 PM
Jeroen Bakker (jbakker) mentioned this in rBda6ed54569d0: T55456: EditDrawMode.Jun 13 2018, 2:22 PM
Jeroen Bakker (jbakker) updated the task description.Jun 13 2018, 2:24 PM
Jeroen Bakker (jbakker) updated the task description.Jun 13 2018, 2:45 PM
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).Jun 13 2018, 4:11 PM
re:
selected face should not be rendered with dither mask, but use the solid color (just like verts, edges)
It's no longer possible to tell which face is active in fairly common cases.
Jeroen Bakker (jbakker) mentioned this in rBb8015ece51c2: Revert "T55456: EditDrawMode".Jun 13 2018, 4:34 PM
Jeroen Bakker (jbakker) mentioned this in rB645c91882530: T55456: EditDrawMode.Jun 13 2018, 4:49 PM
Jeroen Bakker (jbakker) mentioned this in rB2e23385c3572: T55456: EditDrawMode.
Jeroen Bakker (jbakker) updated the task description.Jun 14 2018, 9:06 AM
Jeroen Bakker (jbakker) updated the task description.Jun 14 2018, 9:41 AM
Jeroen Bakker (jbakker) updated the task description.Jun 14 2018, 9:52 AM
Jeroen Bakker (jbakker) updated the task description.Jun 14 2018, 12:30 PM
Jeroen Bakker (jbakker) mentioned this in rB277d90127417: T55456 EditMeshMode.Jun 14 2018, 2:20 PM
babajan (johnsyed) added a subscriber: babajan (johnsyed).Jun 14 2018, 8:57 PM
pre selection highlight would be nice its easier and faster to select in edit mode , at least we can have an option in theme settings.
Campbell Barton (campbellbarton) mentioned this in T54940: 2.8: Code-Quest (Maintainer decisions pending).Jun 16 2018, 10:07 AM
Campbell Barton (campbellbarton) added a comment.EditedJun 18 2018, 9:09 AM
This task misses design rationale - it's just a list of changes.
For example - why do we need individual colors for active vertex/edge/face?
"better masking for selected faces" - what does this mean?
"Also facedot." also unclear.
It's important to explain what issues this solves so we can apply the solutions more generally (other object types, UV editor etc). Also, if these changes cause problems elsewhere, we can better compare pros and cons if we have a final design of how things should fit together.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 30.Jun 18 2018, 9:10 AM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Aug 3 2018, 11:07 AM
Any news here? Otherwise, will archive…
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Aug 11 2018, 2:52 PM
Campbell Barton (campbellbarton) mentioned this in rB9d34a9d7e59d: DRW: add back edge highlighting for active face drawing.Feb 28 2019, 8:05 AM
