Maniphest T55475
Crash due to zero uniform buffer binding for sssProfile
Closed, Resolved
Clément Foucault (fclem)
Edmund Kapusniak (edmundmk)
Jun 13 2018, 11:11 PM
  • BF Blender: 2.8
  • EEVEE & Viewport
Arto Kitula (akitula)
Brecht Van Lommel (brecht)
Inês Almeida (brita_)
Roel Koster (kostex)
macOS 10.12.6
Intel Iris Graphics 6100 1536 MB
Broken: 2f3e890b94e blender2.8 (modified) (built from head of blender2.8 branch)
Blender crashes in macOS Intel OpenGL driver when rendering materials due to 0 being bound to the 'sssProfile' uniform block.
  • Open Blender.
  • In the Properties Editor, select the Material tab.
  • Use the dropdown near the top left of the window to switch the main area to the Shader Editor.
  • In the Properties Editor, enable and disable 'Use Nodes' several times.
  • Blender will crash with the following backtrace:
* thread #18, stop reason = EXC_BAD_ACCESS (code=1, address=0x100)
  * frame #0: 0x00007fff84799178 IOAccelerator`IOAccelContextAddResource + 8
    frame #1: 0x0000000117dcffa0 AppleIntelBDWGraphicsGLDriver`void updateBindingTable<SGfx3dStateBindingTablePointers>(GenContext*, unsigned int, SGfx3dStateBindingTablePointers&) + 2887
    frame #2: 0x0000000117dcc9f3 AppleIntelBDWGraphicsGLDriver`GenContext::ProgramPipeline() + 15463
    frame #3: 0x0000000117deabdd AppleIntelBDWGraphicsGLDriver`glrIntelRenderVertexArray + 391
    frame #4: 0x000000011780bbc5 GLEngine`glDrawRangeElements_GL3Exec + 315
    frame #5: 0x00007fff79ea1980 libGL.dylib`glDrawRangeElements + 45
    frame #6: 0x0000000105ae43c4 blender`GWN_batch_draw_range_ex(batch=0x000060d00034d860, v_first=0, v_count=23040, force_instance=false) at gwn_batch.c:710
    frame #7: 0x0000000100eb1b2e blender`draw_geometry_execute_ex(shgroup=0x0000631000461c40, geom=0x000060d00034d860, start=0, count=0, draw_instance=false) at draw_manager_exec.c:847
    frame #8: 0x0000000100eb1f06 blender`draw_geometry_execute(shgroup=0x0000631000461c40, geom=0x000060d00034d860) at draw_manager_exec.c:854
    frame #9: 0x0000000100eb0fb6 blender`draw_shgroup(shgroup=0x0000631000461c40, pass_state=525346) at draw_manager_exec.c:1159
    frame #10: 0x0000000100eafa44 blender`drw_draw_pass_ex(pass=0x0000621000d00040, start_group=0x0000631000461ba0, end_group=0x0000631000461c40) at draw_manager_exec.c:1232
    frame #11: 0x0000000100eaf954 blender`DRW_draw_pass(pass=0x0000621000d00040) at draw_manager_exec.c:1265
    frame #12: 0x0000000100ee6b8c blender`EEVEE_draw_default_passes(psl=0x00006210002abd38) at eevee_materials.c:1753
    frame #13: 0x0000000100ee9b06 blender`EEVEE_render_draw(vedata=0x000061700051bbb8, engine=0x00006180001728b8, rl=0x0000611000619bf8, rect=0x0000700007b66b88) at eevee_render.c:510
    frame #14: 0x0000000100ed4dad blender`eevee_render_to_image(vedata=0x000061700051bbb8, engine=0x00006180001728b8, render_layer=0x0000611000619bf8, rect=0x0000700007b66b88) at eevee_engine.c:414
    frame #15: 0x0000000100ea7455 blender`DRW_render_to_image(engine=0x00006180001728b8, depsgraph=0x0000611000379a38) at draw_manager.c:1548
    frame #16: 0x0000000100868a74 blender`RE_engine_render(re=0x000062200012d938, do_all=0) at external_engine.c:740
    frame #17: 0x000000010087aff5 blender`do_render_3d(re=0x000062200012d938) at pipeline.c:1082
    frame #18: 0x000000010087d357 blender`RE_PreviewRender(re=0x000062200012d938, bmain=0x000061c00025d0b8, sce=0x000062200021c138) at pipeline.c:2624
    frame #19: 0x00000001007751a7 blender`shader_preview_render(sp=0x0000611000373778, id=0x0000614000021078, split=0, first=0) at render_preview.c:750
    frame #20: 0x0000000100774b81 blender`shader_preview_startjob(customdata=0x0000611000373778, stop=0x000061300037246c, do_update=0x000061300037246a) at render_preview.c:787
    frame #21: 0x0000000100774469 blender`common_preview_startjob(customdata=0x0000611000373778, stop=0x000061300037246c, do_update=0x000061300037246a, UNUSED_progress=0x0000613000372470) at render_preview.c:1026
    frame #22: 0x0000000100160f67 blender`do_job_thread(job_v=0x00006130003723f8) at wm_jobs.c:337
    frame #23: 0x0000000101628cc1 blender`tslot_thread_start(tslot_p=0x000060b0003fdd38) at threads.c:253
    frame #24: 0x00007fff8b3f093b libsystem_pthread.dylib`_pthread_body + 180
    frame #25: 0x00007fff8b3f0887 libsystem_pthread.dylib`_pthread_start + 286
    frame #26: 0x00007fff8b3f008d libsystem_pthread.dylib`thread_start + 13
Investigation
I have debugged and managed to track the crash down to a missing uniform buffer. When the crash occurs, the active shader program has an active uniform block 'sssProfile'.
For the 'sssProfile' uniform block, GL_UNIFORM_BLOCK_BINDING is 0.
For uniform binding 0, GL_UNIFORM_BUFFER_BINDING is 0.
Therefore, there is no uniform buffer bound to the 'sssProfile' uniform block. I suspect there is also no texture bound to the 'sssTexProfile' sampler either. I am assuming for this shader this uniform block is coming from lamps_lib.glsl, although an identical uniform block is also present in effect_subsurface_frag.glsl.
I can prevent the crash by binding a dummy uniform buffer of the correct size to 'sssProfile'. In this case the rendering of the material in the preview appears corrupt.
I tried adding an #if !defined(USE_TRANSLUCENCY) || defined(VOLUMETRICS) around the uniform block and corresponding sss_profile function in the glsl file, but the problem persists. I suspect that there is a case where this uniform block is actually being accessed without the uniform buffer being bound.
My check for missing uniform buffers also fires on 'clip_block' in other shaders.
Related Objects
Mentioned In
rB3578212e462d: Eevee: Fix missing UBO binds.
Mentioned Here
rB2a8413a0dddb: Eevee: Don't show probe display when not using scene lighting
rBf50fa4c5d69a: Fix T56120: Crash on "Install Matcap, World or Camera HDRI"
rB2f3e890b94eb: DRW: Fix crash caused by hair transform feedback
Edmund Kapusniak (edmundmk) created this task.Jun 13 2018, 11:11 PM
Brecht Van Lommel (brecht) assigned this task to Clément Foucault (fclem).Jun 14 2018, 6:33 PM
Brecht Van Lommel (brecht) added subscribers: Clément Foucault (fclem), Brecht Van Lommel (brecht).
Assigning to @Clément Foucault (fclem) for advice.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Jul 20 2018, 4:10 PM
Bastien Montagne (mont29) added a project: GPU / Viewport.
Clément Foucault (fclem) added a comment.Jul 23 2018, 8:50 PM
There was a bad free of Uniform buffer as well as framebuffers that happened when using the shader preview. This was fixed.
@Edmund Kapusniak (edmundmk) can you still reproduce with latest build?
Edmund Kapusniak (edmundmk) added a comment.Jul 29 2018, 12:55 PM
Unfortunately yes, the crash is intermittent but still happens in build dated 2018-07-28, hash f50fa4c5d69.
Same repro steps:
  • Open Blender.
  • Switch to Materials tab of the Properties Editor.
  • Open the Preview of the material.
  • Switch to Shader Editor in main area.
  • Enable Use Nodes.
  • Blender will sometimes crash.
  • If it doesn't crash, the material preview will display with artefacts.
Here is the backtrace from the Apple crash report dialog, very similar to the backtrace above:
Thread 16:
0   com.apple.IOAccelerator       	0x00007fff95875178 IOAccelContextAddResource + 8
1   com.apple.driver.AppleIntelBDWGraphicsGLDriver	0x000000011339cfa0 void updateBindingTable<SGfx3dStateBindingTablePointers>(GenContext*, unsigned int, SGfx3dStateBindingTablePointers&) + 2887
2   com.apple.driver.AppleIntelBDWGraphicsGLDriver	0x00000001133999f3 GenContext::ProgramPipeline() + 15463
3   com.apple.driver.AppleIntelBDWGraphicsGLDriver	0x00000001133b7bdd glrIntelRenderVertexArray + 391
4   GLEngine                      	0x0000000112dd8bc5 glDrawRangeElements_GL3Exec + 315
5   libGL.dylib                   	0x00007fff8af7d980 glDrawRangeElements + 45
6   org.blenderfoundation.blender 	0x000000010679a6ee GPU_batch_draw_range_ex + 494
7   org.blenderfoundation.blender 	0x00000001067e2f5a drw_draw_pass_ex + 1738
8   org.blenderfoundation.blender 	0x0000000106805026 EEVEE_render_draw + 1510
9   org.blenderfoundation.blender 	0x00000001067dc277 DRW_render_to_image + 695
10  org.blenderfoundation.blender 	0x000000010654dd6d RE_engine_render + 973
11  org.blenderfoundation.blender 	0x00000001064b41c2 shader_preview_render + 530
12  org.blenderfoundation.blender 	0x00000001064b3bf2 common_preview_startjob + 370
13  org.blenderfoundation.blender 	0x00000001061ce2ff do_job_thread + 31
14  libsystem_pthread.dylib       	0x00007fff9c4d093b _pthread_body + 180
15  libsystem_pthread.dylib       	0x00007fff9c4d0887 _pthread_start + 286
16  libsystem_pthread.dylib       	0x00007fff9c4d008d thread_start + 13
The crash appears to be somehow timing dependent - performing the repro steps quickly will result in a greater chance of it crashing. I have attached a screenshot of the artefacts on the material.
Edmund Kapusniak (edmundmk) added a comment.Jul 29 2018, 1:45 PM
Here is a patch for gpu_batch.c that detects when there are missing uniform buffers.
With PREVENT_CRASH defined, a dummy uniform buffer is created and bound to the missing active uniform blocks. In this case, the materials still render with artefacts, but I have not been able to reproduce the crash.
Example output while rendering material previews with this patch applied:
ZERO BUFFER: common_block -> 0 -> 0 [464]
ZERO BUFFER: clip_block -> 0 -> 0 [16]
ZERO BUFFER: sssProfile -> 0 -> 0 [1072]
Arto Kitula (akitula) added subscribers: Roel Koster (kostex), Arto Kitula (akitula), Inês Almeida (brita_).
Arto Kitula (akitula) added a comment.Jul 29 2018, 9:05 PM
This is indeed Intel-only thing. I can crash blender on GPU_batch_draw_range_ex when enabling only Intel GPU on my MacBookPro.
Clément Foucault (fclem) mentioned this in rB3578212e462d: Eevee: Fix missing UBO binds..Aug 2 2018, 6:36 PM
Clément Foucault (fclem) added a comment.Aug 2 2018, 9:15 PM
Should be fixed by rB3578212e462d2a67f49d64ce5fb64df43200654f
@Edmund Kapusniak (edmundmk) Thanks for the patch it was very helpful. I integrated it to the debug build.
@Arto Kitula (akitula) Can you try again with the latest build?
Roel Koster (kostex) added a comment.Aug 2 2018, 10:17 PM
I've built blender 2a8413a0ddd
So far I can say it's a stable build regarding this issue!
Cool!
Arto Kitula (akitula) changed the task status from Unknown Status to Resolved.Aug 4 2018, 2:01 PM
@Clément Foucault (fclem) tested, works. marking as resolved.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:12 PM
