Maniphest T56140
Viewport crashes
Closed, Resolved
Sergey Sharybin (sergey)
Lincoln Deen (Linkun)
Jul 29 2018, 8:06 PM
  • BF Blender
Bastien Montagne (mont29)
s12a (s12a)
MS Windows 10, intel core i5, Nvidia GTX 745
Broken: bd6d0b94bc1 (2.8 alpha)
Worked: 7.9b
Crashes consistently when playing particle animations in the viewport, typically gets a few frames in before crashing. Frame dropping dosen't help.
Related Objects
Mentioned Here
rB98c304e865f8: Gizmo: add option to catch all mouse clicks
T56313: Crash - selecting tools: Transform, Grab, Rotate and Scale.
rBff1ca80f0101: Set overlay default values
rBbd6d0b94bc17: Fix T55744: Assertion failure using the Knife angle constraint option
Lincoln Deen (Linkun) created this task.Jul 29 2018, 8:06 PM
Vuk Gardašević (lijenstina) edited projects, added BF Blender: 2.8; removed BF Blender.Jul 29 2018, 8:07 PM
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Jul 30 2018, 11:45 AM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Cannot reproduce here on linux with latest 2.8, so this is likely another OpenGL issue. Please:
  • Give us your exact Blender, OS and GPU (including drivers) versions, as requested in the template!
  • Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker or open source ones in linux distributions).
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Try to tweak OGL settings in UserPreferences, System tab.
  • Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
  • Attach as text file here the report generated by Help -> System Info (do not paste it directly in comment).
  • Launch Blender from the command line with --debug-gpu option and attach as text file here any error printed out in the console (do not paste it directly in comment).
s12a (s12a) added a subscriber: s12a (s12a).Jul 31 2018, 4:20 PM
I could reproduce on ff1ca80f010 and:
  • Windows 10 Pro x64 (1803)
  • AMD Radeon RX480 4GB with Radeon Software 18.7.1
However, it took several tries. It appears that selecting/deselecting everything and trying to move the view with MMB while the animation is playing increases the chances of seeing the issue.
Attached console output and backtrace from a debug build.
Bastien Montagne (mont29) claimed this task.Aug 9 2018, 11:37 AM
Bastien Montagne (mont29) raised the priority of this task from 30 to 50.
Indeed, using (de)select all could reproduce the crash here on linux too, checking…
Bastien Montagne (mont29) reassigned this task from Bastien Montagne (mont29) to Sergey Sharybin (sergey).Aug 11 2018, 5:25 PM
Bastien Montagne (mont29) added a subscriber: Sergey Sharybin (sergey).
(note: file currently crashes on opening due to another issue, due to T56313, you need to go before rB98c304e865f87a658778781f4280107ed449091c to investigate).
@Sergey Sharybin (sergey) threading issue in particle code I think, see ASAN log below.
==4917==ERROR: AddressSanitizer: heap-use-after-free on address 0x61800001e080 at pc 0x55ba45a53db5 bp 0x7fd1b2daa9e0 sp 0x7fd1b2daa9d8
READ of size 8 at 0x61800001e080 thread T19
    #0 0x55ba45a53db4 in MEM_lockfree_allocN_len /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:120
    #1 0x55ba45a53de8 in MEM_lockfree_freeN /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:130
    #2 0x55ba44b1d8d9 in ptcache_data_free /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:2214
    #3 0x55ba44b24e87 in BKE_ptcache_id_clear /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:3076
    #4 0x55ba44b26859 in BKE_ptcache_id_reset /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:3304
    #5 0x55ba44b26c73 in BKE_ptcache_object_reset /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:3339
    #6 0x55ba454cb00f in int std::__invoke_impl<int, int (*&)(Scene*, Object*, int), Scene*&, Object*&, int&>(std::__invoke_other, int (*&)(Scene*, Object*, int), Scene*&, Object*&, int&) /usr/include/c++/8/bits/invoke.h:60
    #7 0x55ba454c908c in std::__invoke_result<int (*&)(Scene*, Object*, int), Scene*&, Object*&, int&>::type std::__invoke<int (*&)(Scene*, Object*, int), Scene*&, Object*&, int&>(int (*&)(Scene*, Object*, int), Scene*&, Object*&, int&) /usr/include/c++/8/bits/invoke.h:95
    #8 0x55ba454c69c0 in int std::_Bind<int (*(Scene*, Object*, int))(Scene*, Object*, int)>::__call<int, Depsgraph*&&, 0ul, 1ul, 2ul>(std::tuple<Depsgraph*&&>&&, std::_Index_tuple<0ul, 1ul, 2ul>) /usr/include/c++/8/functional:400
    #9 0x55ba454c2ea7 in int std::_Bind<int (*(Scene*, Object*, int))(Scene*, Object*, int)>::operator()<Depsgraph*, int>(Depsgraph*&&) /usr/include/c++/8/functional:484
    #10 0x55ba454bdd28 in std::_Function_handler<void (Depsgraph*), std::_Bind<int (*(Scene*, Object*, int))(Scene*, Object*, int)> >::_M_invoke(std::_Any_data const&, Depsgraph*&&) /usr/include/c++/8/bits/std_function.h:297
    #11 0x55ba454f2ddb in std::function<void (Depsgraph*)>::operator()(Depsgraph*) const /usr/include/c++/8/bits/std_function.h:687
    #12 0x55ba454f14a6 in deg_task_run_func /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/eval/deg_eval.cc:94
    #13 0x55ba45464cce in handle_local_queue /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:419
    #14 0x55ba45464cce in task_scheduler_thread_run /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:448
    #15 0x7fd1edc54f29 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x7f29)
    #16 0x7fd1e6368ede in __clone (/lib/x86_64-linux-gnu/libc.so.6+0xf7ede)
0x61800001e080 is located 0 bytes inside of 856-byte region [0x61800001e080,0x61800001e3d8)
freed by thread T15 here:
    #0 0x7fd1ef725b50 in __interceptor_free (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xe8b50)
    #1 0x55ba45a5408e in MEM_lockfree_freeN /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:164
    #6 0x55ba44ad8ddd in BKE_particle_system_eval_init /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/particle_system.c:4440
    #7 0x55ba454caa0d in void std::__invoke_impl<void, void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(std::__invoke_other, void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) /usr/include/c++/8/bits/invoke.h:60
    #8 0x55ba454c8793 in std::__invoke_result<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>::type std::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) /usr/include/c++/8/bits/invoke.h:95
    #9 0x55ba454c5f64 in void std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)>::__call<void, Depsgraph*&&, 0ul, 1ul, 2ul>(std::tuple<Depsgraph*&&>&&, std::_Index_tuple<0ul, 1ul, 2ul>) /usr/include/c++/8/functional:400
    #10 0x55ba454c1d3b in void std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)>::operator()<Depsgraph*, void>(Depsgraph*&&) /usr/include/c++/8/functional:484
    #11 0x55ba454bc913 in std::_Function_handler<void (Depsgraph*), std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)> >::_M_invoke(std::_Any_data const&, Depsgraph*&&) /usr/include/c++/8/bits/std_function.h:297
    #12 0x55ba454f2ddb in std::function<void (Depsgraph*)>::operator()(Depsgraph*) const /usr/include/c++/8/bits/std_function.h:687
    #13 0x55ba454f14a6 in deg_task_run_func /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/eval/deg_eval.cc:94
    #14 0x55ba45464949 in task_scheduler_thread_run /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:441
previously allocated by thread T16 here:
    #0 0x7fd1ef7260b8 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xe90b8)
    #1 0x55ba45a54513 in MEM_lockfree_callocN /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:282
    #2 0x55ba44b1d7b3 in ptcache_data_alloc /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:2204
    #3 0x55ba44b22f4b in ptcache_write /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:2814
    #4 0x55ba44b23d0e in BKE_ptcache_write /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/pointcache.c:2940
    #5 0x55ba44ad4f22 in system_step /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/particle_system.c:4085
    #6 0x55ba44ad857a in particle_system_update /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/particle_system.c:4362
    #7 0x55ba43a020f2 in deformVerts /home/i74700deb64/blender/__work__/src/source/blender/modifiers/intern/MOD_particlesystem.c:215
    #8 0x55ba449bc7e9 in modifier_deformVerts /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/modifier.c:895
    #9 0x55ba449bca65 in modifier_deformVerts_ensure_normals /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/modifier.c:921
    #10 0x55ba445fde91 in mesh_calc_modifiers /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/DerivedMesh.c:2221
    #11 0x55ba44604350 in mesh_build_data /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/DerivedMesh.c:2950
    #12 0x55ba44604f63 in makeDerivedMesh /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/DerivedMesh.c:3060
    #13 0x55ba44a49b27 in BKE_object_handle_data_update /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/object_update.c:205
    #14 0x55ba44a4a75d in BKE_object_eval_uber_data /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/object_update.c:311
    #15 0x55ba454caa0d in void std::__invoke_impl<void, void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(std::__invoke_other, void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) /usr/include/c++/8/bits/invoke.h:60
    #16 0x55ba454c8793 in std::__invoke_result<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>::type std::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) /usr/include/c++/8/bits/invoke.h:95
    #17 0x55ba454c5f64 in void std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)>::__call<void, Depsgraph*&&, 0ul, 1ul, 2ul>(std::tuple<Depsgraph*&&>&&, std::_Index_tuple<0ul, 1ul, 2ul>) /usr/include/c++/8/functional:400
    #18 0x55ba454c1d3b in void std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)>::operator()<Depsgraph*, void>(Depsgraph*&&) /usr/include/c++/8/functional:484
    #19 0x55ba454bc913 in std::_Function_handler<void (Depsgraph*), std::_Bind<void (*(std::_Placeholder<1>, Scene*, Object*))(Depsgraph*, Scene*, Object*)> >::_M_invoke(std::_Any_data const&, Depsgraph*&&) /usr/include/c++/8/bits/std_function.h:297
    #20 0x55ba454f2ddb in std::function<void (Depsgraph*)>::operator()(Depsgraph*) const /usr/include/c++/8/bits/std_function.h:687
    #21 0x55ba454f14a6 in deg_task_run_func /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/eval/deg_eval.cc:94
    #22 0x55ba45464cce in handle_local_queue /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:419
    #23 0x55ba45464cce in task_scheduler_thread_run /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:448
    #24 0x7fd1edc54f29 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x7f29)
Thread T19 created by T0 here:
    #0 0x7fd1ef686ef0 in pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x49ef0)
    #1 0x55ba454652b1 in BLI_task_scheduler_create /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:504
    #2 0x55ba4546c5e9 in BLI_task_scheduler_get /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:176
    #3 0x55ba4546b00b in BLI_task_parallel_range /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/task.c:1099
    #4 0x55ba454f944d in flush_prepare /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/eval/deg_eval_flush.cc:122
    #5 0x55ba454f944d in DEG::deg_graph_flush_updates(Main*, DEG::Depsgraph*) /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/eval/deg_eval_flush.cc:359
    #6 0x55ba454a7d68 in DEG_graph_flush_update /home/i74700deb64/blender/__work__/src/source/blender/depsgraph/intern/depsgraph_tag.cc:635
    #7 0x55ba44b50d70 in BKE_scene_graph_update_tagged /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/scene.c:1425
    #8 0x55ba422d4b6d in wm_event_do_depsgraph /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:336
    #9 0x55ba422f4916 in wm_file_read_post /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_files.c:493
    #10 0x55ba422f62e7 in wm_homefile_read /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_files.c:897
    #11 0x55ba423075e7 in WM_init /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_init_exit.c:253
    #12 0x55ba422c1464 in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:438
    #13 0x7fd1e6293b16 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x22b16)
Thread T15 created by T0 here:
Thread T16 created by T0 here:
SUMMARY: AddressSanitizer: heap-use-after-free /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:120 in MEM_lockfree_allocN_len
Shadow bytes around the buggy address:
  0x0c307fffbbc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c307fffbbd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c307fffbbe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c307fffbbf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 fa
  0x0c307fffbc00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x0c307fffbc10:[fd]fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
  0x0c307fffbc20: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
  0x0c307fffbc30: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
  0x0c307fffbc40: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
  0x0c307fffbc50: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
  0x0c307fffbc60: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
Shadow byte legend (one shadow byte represents 8 application bytes):
  Addressable:           00
  Partially addressable: 01 02 03 04 05 06 07
  Heap left redzone:       fa
  Freed heap region:       fd
  Stack left redzone:      f1
  Stack mid redzone:       f2
  Stack right redzone:     f3
  Stack after return:      f5
  Stack use after scope:   f8
  Global redzone:          f9
  Global init order:       f6
  Poisoned by user:        f7
  Container overflow:      fc
  Array cookie:            ac
  Intra object redzone:    bb
  ASan internal:           fe
  Left alloca redzone:     ca
  Right alloca redzone:    cb
==4917==ABORTING
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed BF Blender: 2.8.Dec 11 2018, 3:09 PM
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Jan 23 2019, 12:43 PM
Can no longer reproduce the issue. There were a lot of fixes in related areas, so most likely the issue has been fixed.
if it's not, please submit a new report, with an updated information.
