Maniphest T56160
Stabilize boolean's epsilon use, write tests
Confirmed, NormalTO DO
Jul 31 2018, 3:52 AM
  • BF Blender
  • Modeling
Akshat Dixit (:baka) (aaka)
Bastien Montagne (mont29)
Brecht Van Lommel (brecht)
Dalai Felinto (dfelinto)
Habib Gahbiche (zazizizou)
Sergey Sharybin (sergey)
Motivation: resolve bugs in boolean code.
Description:
Currently booleans use epsilon comparisons in a non-uniform way,
causing near edge-cases for fall in-between detecting a segment and an end-point intersection.
This would resolve some of the open bug reports we have now.
Estimated Time: 2 weeks
  • 1 week writing tests, make sure existing bug reports are covered by these tests.
    This is very important since currently there aren't any good ways to know if a change to boolean code breaks edge cases.
  • 1 week (max) to go over current boolean code and make all comparisons uniform
    (may be a day or two as well, just needs to be done carefully, possibly re-working intersection code)
Related Objects
StatusSubtypeAssignedTask
ConfirmedTO DONone
ConfirmedTO DOCampbell Barton (campbellbarton)
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Normal.Jul 31 2018, 3:52 AM
Campbell Barton (campbellbarton) created this task.
Campbell Barton (campbellbarton) updated the task description.Jul 31 2018, 3:54 AM
Aaron Carlisle (Blendify) added a project: Modeling.Jan 27 2020, 2:40 AM
Aaron Carlisle (Blendify) mentioned this in T63731: Modeling Module.
Habib Gahbiche (zazizizou) added a subscriber: Habib Gahbiche (zazizizou).Mar 22 2020, 2:29 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Long Term on the Modeling board.Jun 17 2020, 5:01 AM
Akshat Dixit (:baka) (aaka) added a subscriber: Akshat Dixit (:baka) (aaka).EditedApr 8 2021, 9:21 PM
I would like to work on this issue...I just need a little information, what can I do to explore and understand the issue!
Edit: I found out about what booleans are in the blender. I know and understand testing works in the blender, I would like some pre-information.
  • What kind of tests are expected ('Edge cases')?
  • What way should I implement them(make a new test file for booleans in test/ directory with a new blend file or add something to an existing one )?
