Maniphest T56210
Blender 2.79, latest build - undo doesn't work in certain cases
Closed, Archived
None
Catalin (giakaama)
Aug 2 2018, 12:00 PM
  • BF Blender
Bastien Montagne (mont29)
Catalin (giakaama)
GeForce GTX 950/PCIe/SSE2
Broken: (2.79 (sub 6), branch: blender2.8, commit date: 2018-08-01 17:44, hash: e50a3dd4c4e, type: Release build date: 01/08/2018, 19:44)
Worked: (2.79b , hash: f4dc9f9d68b, Date: 2018-03-22 )
Undo doesn't work . In certain cases .
  1. Open the blend file.
  2. Apply a boolean modifier on the big object
  3. Set it to difference
  4. Set the small rectangle to be the cutter
  5. Deselect All
  6. Press CTRL+Z ( it doesn't work the boolean it's not removed )
Related Objects
Mentioned Here
rBf4dc9f9d68bd: Fix T54360: FFMPEG bitrate not editable for all codecs
rBe50a3dd4c4e9: Fix T56197: Cycles OpenCL build error after recent changes.
Catalin (giakaama) renamed this task from Blender 2.79 LATEST to Blender 2.79, latest build - undo doesn't work in certain cases.Aug 2 2018, 12:00 PM
Catalin (giakaama) created this task.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Aug 2 2018, 5:33 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Not sure what you mean exactly, what do you get as result and what do you expect?
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Catalin (giakaama) added a comment.Aug 2 2018, 10:18 PM
The result I get is that the boolean doesn't get's removed by Ctrl+Z, the undo doesn't undo the opperation, it does nothing . I want the same result I get with 2.79b , hash: f4dc9f9d68b from Steam .
I've completed every step you have in submission template ... I don't know how many more info to give ...
Catalin (giakaama) raised the priority of this task from 30 to 90.Aug 2 2018, 10:21 PM
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).EditedAug 3 2018, 6:04 AM
Cant redo this.
The de-select action is skipped. but the boolean is undone as expected.
From what I can tell the only bug is that changing the boolean target object is not causing an undo step.
Catalin (giakaama) added a comment.Aug 3 2018, 8:48 AM
In T56210#524200, @Campbell Barton (campbellbarton) wrote:
Cant redo this.
Agreed, just found out that I get this behavior because I sync Blender over Dropbox . When do those steps localy they work . So this task should be closed .
Catalin (giakaama) changed the task status from Unknown Status to Unknown Status.Aug 3 2018, 8:49 AM
