Windows 10 Pro 64Bit
NVidia P4000
All Drivers up to date
Broken: Blender 2.8 5b6dde22935
Worked: NA
Blender crashes when adjusting normal strength or segments once Normal Mode is set to "Face Area". This crash occurs whether the number is directly entered with the keyboard or if the slider is adjusted.
- Open Blender, Select Default Cube
- Add Bevel Modifier
- Set Segments to "3"
- Set Normal Mode to "Face Area"
- Set Normal Strength to "1"
- Watch Blender Crash
Note: Steps 3 and 5 can be reversed. In this case, with Normal Strength set to 1, adjust the segments count to a number other than one.
To reproduce in the blend file, go to the bevel modifier for the cube and adjust the Normal Strength up to 1.
