Maniphest T56531
Blender not responding
Closed, Archived
Bastien Montagne (mont29)
Samantha Jones (HAKERO)
Aug 25 2018, 3:37 AM
  • BF Blender
Stephen Swaney (stiv)
Yevgeny Makarov (jenkm)
Windows 8.1 64-bit operating system
AMD FX(tm) 8350 Eight- Core Processor
NVIDIA GeForce GTX 1050 Ti
Blender 2.79b
2018-03-22 14:10
Hash: f4dc9f9d68b
Broken: (example: 2.69.7 4b206af, see splash screen)
Currently having long delays when attempting to apply weight paint to my model, blender will stop responding.
I already riged my character.
I have the same issue when trying to apply vortex paint.
It will crash rarely.
Select model or clothing, anything at all rigged.
Go into weight paint, subtract to remove some of the red.
It will delay, stop responding for 11 seconds or more and then proceed on the steps taken.
Related Objects
Mentioned Here
rBf4dc9f9d68bd: Fix T54360: FFMPEG bitrate not editable for all codecs
Samantha Jones (HAKERO) created this task.Aug 25 2018, 3:37 AM
Samantha Jones (HAKERO) updated the task description.Aug 25 2018, 3:45 AM
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Aug 25 2018, 3:50 AM
Stephen Swaney (stiv) added a subscriber: Stephen Swaney (stiv).
  • MISSING INFO
Please attach a .blend showing the problem.
Marking as "Incomplete" until the requested information/data is provided.
Samantha Jones (HAKERO) added a comment.EditedAug 25 2018, 4:09 AM
I am not sure how to attach a .blend file.
But here are some photos i took showing what happens every time i try to use weight paint.
  1. I go to weight paint
  1. I selected where i want to paint.
  1. Once i begin to paint the cursor will freeze in one spot, blender will freeze and will then for 11 seconds or more will stop responding altogether.
  1. It will resume responding, but will only show the small change i had made since i would not move my cursor.
This happens every time i try to paint anything at all in weight paint.
Let me know if further data needs to be provided.
Samantha Jones (HAKERO) raised the priority of this task from 30 to Normal.Aug 25 2018, 5:28 AM
Yevgeny Makarov (jenkm) triaged this task as 30 priority.Aug 25 2018, 6:14 AM
Yevgeny Makarov (jenkm) added a subscriber: Yevgeny Makarov (jenkm).
@Samantha Jones (HAKERO)
The cloud icon above the text field, drag-and-drop also works.
The file is required to reproduce the problem.
Remove all unnecessary, leave only objects that cause problems.
And not change priority yourself, leave it to the moderators.
Yevgeny Makarov (jenkm) added a comment.EditedAug 25 2018, 6:24 AM
...and it seems you have a problem with the mesh (too much subdivided, overlapped, check it out first).
Tris: 2,888,816
Mem: 3764.28
Samantha Jones (HAKERO) added a comment.Aug 25 2018, 6:57 AM
This comment was removed by Samantha Jones (HAKERO).
noki paike (amonpaike) added a subscriber: noki paike (amonpaike).Aug 25 2018, 3:10 PM
lol a "little" blend file of 1 GB
probably "the bug" is saturation of the memory
Samantha Jones (HAKERO) removed a subscriber: Samantha Jones (HAKERO).Aug 25 2018, 3:30 PM
Samantha Jones (HAKERO) added a subscriber: Samantha Jones (HAKERO).
Samantha Jones (HAKERO) removed a subscriber: noki paike (amonpaike).Aug 25 2018, 3:32 PM
Samantha Jones (HAKERO) added a comment.EditedAug 25 2018, 4:33 PM
Hi, i saved with compression.
I forgot to beforehand and sent a 1gb file.
I am rather new to blender, i know a few basics.
Is there a good outline to follow in terms of mesh?
Tris: 2,888,816
Mem: 3764.28
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Sep 3 2018, 4:42 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Still no .blend file… But indeed, with nearly 3 millions triangles weight painting is going to be complicated, especially since (judging from your screencaptures) you have a few areas (the snake around the arm) with insanely dense geometry, and probably even overlapping faces, while most of the mesh looks OK. This means a large amount of the 3M triangles are under the painting brush at the same time, you cannot expect any fluid work here.
Just sanitize your geometry first. Also, We do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
