Maniphest T56580
Blender 2.79
Closed, Archived
Bastien Montagne (mont29)
Roger Sexton (rogersexton)
Aug 28 2018, 2:39 AM
  • BF Blender
Stephen Swaney (stiv)
Yevgeny Makarov (jenkm)
Hello,
I was trying to use Blender 2.79. And the "System" window in the "User Preferences" is not coming up right.
I would send you a picture of the screen that comes up but I see that is not possible here.
As described, it only shows six lines with information in the boxes or buttons.
This happen after I attempted to load a new Python into the software.
How can I fix this. The same software comes up on the college systems from my flash drive.
But on my home system it comes up as I have explained.
I have downloaded a new file for the same version and it still does not work.
Kind regards.
Roger
RDS2@Q.Com
RogDS0@Gmail.Com
Related Objects
Roger Sexton (rogersexton) created this task.Aug 28 2018, 2:39 AM
Hello,
Kind regards.
Roger
RDS2@Q.Com
RogDS0@Gmail.Com
Yevgeny Makarov (jenkm) added a subscriber: Yevgeny Makarov (jenkm).Aug 28 2018, 6:30 AM
As said before T54930 we would need more information.
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Aug 28 2018, 6:36 AM
Stephen Swaney (stiv) added a subscriber: Stephen Swaney (stiv).
Problems popping up the User Prefs window are usually due to your video card/driver.
You can change to User Prefs using the editor dropdown menu instead of File->User Prefs.
  • MISSING INFO
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Sep 4 2018, 9:31 AM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Note that you can access userpref also by changing type of e.g. 3DView in main window, not only as a new window.
