Maniphest T56636
Custom property cannot be animated
Closed, Resolved
None
Antonio Vazquez (antoniov)
Aug 31 2018, 10:22 PM
  • BF Blender: 2.8
  • Animation & Rigging
Bastien Montagne (mont29)
Joshua Leung (aligorith)
Philipp Oeser (lichtwerk)
Sergey Sharybin (sergey)
Blender2.8 Windows 64 bits version 30/08/2018 20:49
If you add a keyframe using I key over the custom property, if you move timeline, you cannot change or animate the custom property.
To reproduce:
  1. Open attached file.
  2. Select cube and in custom properties set "hide" property to 0
  3. Over "hide" property, press I to insert keyframe
  4. Move the timeline and try to change hide prop or insert a new keyframe
I noticed also some random blender crashes when clear the property keyframe of hide property.
I have tested the same in 2.79b and works.
Revisions and Commits
rB Blender
Antonio Vazquez (antoniov) created this task.Aug 31 2018, 10:22 PM
Antonio Vazquez (antoniov) edited projects, added BF Blender: 2.8; removed BF Blender.
Antonio Vazquez (antoniov) added a comment.Aug 31 2018, 10:25 PM
I have pasted the log of one the crashes P775
Antonio Vazquez (antoniov) added a comment.Aug 31 2018, 10:53 PM
I could reproduce the error with the default scene:
  1. Open default scene
  2. Select default cube
  3. Add a custom prop (the default name is prop)
  4. Press N and in properties enter any value to "prop"
  5. Press I over prop
  6. Now try to move timeline and insert a new value in the prop.
Antonio Vazquez (antoniov) added a project: Animation & Rigging.Sep 2 2018, 8:09 PM
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Sep 3 2018, 4:22 PM
Bastien Montagne (mont29) added subscribers: Sergey Sharybin (sergey), Joshua Leung (aligorith), Bastien Montagne (mont29).
Reminds me of similar issue with some VSE properties in 2.7x… IIRC, animation gets re-evaluated when editing those values, hence they get reset to animated value immediately…
@Joshua Leung (aligorith), @Sergey Sharybin (sergey), not sure whether we have standard fix for those cases?
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Oct 19 2018, 1:14 PM
@Antonio Vazquez (antoniov): asked in IRC if I could also have a look, and here are my findings (sorry for the lengthy detour, this might all be totally obvious for others...)
Changing a value in a (already keyed) custom property will go through dependency graph DEG_OPCODE_ANIMATION and thus calls BKE_animsys_eval_animdata (where this all gets evaluated/reset to the current fcurve value)
deg_graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, TIME, triggered here
Changing a value for e.g. posx wont do this:
deg_graph_id_tag_update: id=OBCube flags=COPY_ON_WRITE
if I remove the TIME dependency (like P802), this will obviously work (but will probably lack updates elsewhere [drivers...])
From comments in code I was first expecting AnimOverride to take care of this [see animsys_evaluate_overrides()], but in fact these dont seem to be used at all?
Will have a look next how this survives in 2.79 with the new dependency graph...
Philipp Oeser (lichtwerk) added a comment.Oct 19 2018, 1:27 PM
Another thing I noticed when having an animated custom property is that even other keyframes might not be evaluated anymore (and this is even true for 2.79 with new depsgraph)...:
  • Open default scene
  • Select default cube
  • Add a custom prop (the default name is prop)
  • Press N and in properties enter any value to "prop"
  • Press I over prop
  • insert single keyframe on locx
  • move one frame forward, change locx to 1, insert single keyframe on locx again
  • change frames --> transform is not updated! [even though it is keyed]
  • this goes back to normal evaluation after file reload
(more detailed depsgraph info in P803)
Sergey Sharybin (sergey) added a comment.Oct 22 2018, 4:17 PM
Initially reported bug is caused by ID properties always tagging for time update. Doing something like this P806 solves the issue.
My guess is this is because old depsgraph was ignoring time update if animation data wasn't tagged for update. The new code with proposed i *think* is correct.
Not sure it's the same issue as @Philipp Oeser (lichtwerk) did report.
Philipp Oeser (lichtwerk) added a comment.Oct 22 2018, 4:34 PM
@Sergey Sharybin (sergey): thought so, too [P802 == P806 :)]
(if that doesnt cause bad stuff elsewhere: great)
second issue remains though [the one with not updating transform -- see above. Should I move this to a separate report?]
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved by committing rBb4ebb9d8efb2: Fix T56636: Custom property cannot be animated.Oct 22 2018, 4:50 PM
Sergey Sharybin (sergey) added a commit: rBb4ebb9d8efb2: Fix T56636: Custom property cannot be animated.
Sergey Sharybin (sergey) mentioned this in rB3c655fd37274: Depsgraph: Fix missing relation update.
