Windows 10 Build 17134
AMD Ryzen Threadripper 1950X 16-Core Processor
Geforce GTX 1080 Ti
Geforce GTX Titan X
Broken: blender-2.80.0-git.41f4d210796
There is no connection between renderlayer node and output node possible if you switch to cycles.
Start Blender
Switch to Compositing Workspace
Klick on "Use nodes"
Switch to render engine Cycles
Add a file output node or in the View Layer Tab switch on Normal Pass in the passes section. - The render layers node looses its output connections.
Switching between the render engines (Eevee, OpenGl, Cycles) sometimes makes the connections appear again but arbitrary.
