OS: Windows 10 Pro
GPU: AMD Radeon RX 580 Series
Broken: 2.79b f4dc9f9d68b
System Preferences
Cycles Compute Device: OpenCL using Radeon RX 580 Series
OpenSubdiv compute: GLSL Compute
Render Preferences
Render - Device - GPU Compute
Cycles renderer used
Trying to render a scene with GPU crashes.
Rendering with command prompt attached gives the message:
"Compiling OpenCL program split
Error: EXCEPTION_ACCESS_VIOLATION"
Using Image Texture nodes as well as Normal Map nodes causes the previous error to occur.
Within Node editor and Table Data selected.
The following connections will crash blender if attempted to render:
- Top Image Texture node to Mix node.
- Normal Map node to Glossy BSDF and Diffuse BSDF nodes.
- Connect any of the nodes listed.
- Render Image.
