Maniphest T56696
grease pencil vertex not showing in edit mode
Closed, Resolved
Antonio Vazquez (antoniov)
Ricardo Diaz (poyodiaz)
Sep 5 2018, 11:07 AM
  • BF Blender: 2.8
  • Grease Pencil
System Information. osx 10,13,6. intel HD grapichs 4000 1536mb
Broken: 2.8 alpha2 hash. 1d04d7721b2
2018-09-03)
grease pencil vertex is not showing in edit mode
also, in draw tools the ratio circle in is not showing, only shows for proportional editing but not on brushes
Related Objects
Mentioned Here
rB1d04d7721b2d: Cleanup: pep8
Ricardo Diaz (poyodiaz) created this task.Sep 5 2018, 11:07 AM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).Sep 5 2018, 11:12 AM
Are you set the vertex opacity > 0 in Overlay panel?
Antonio Vazquez (antoniov) edited projects, added BF Blender: 2.8, Grease Pencil; removed BF Blender.Sep 5 2018, 11:13 AM
Ricardo Diaz (poyodiaz) added a comment.Sep 6 2018, 2:42 AM
how can i do that?
Ricardo Diaz (poyodiaz) added a comment.Sep 6 2018, 2:48 AM
found it, yes, is set to 0, it happens in high sierra and mavericks with the same blender build i mention in original post
Antonio Vazquez (antoniov) added a comment.Sep 6 2018, 8:50 AM
and if you put a value like 1, do you see the vertex?
Ricardo Diaz (poyodiaz) added a comment.Sep 6 2018, 9:00 AM
oh i see, its working but only while the vertex is select is that correct?
Ricardo Diaz (poyodiaz) added a comment.Sep 6 2018, 9:07 AM
its working now, I installed a printer driver yesterday, maybe that was the issue, thanks and sorry :(
Antonio Vazquez (antoniov) changed the task status from Unknown Status to Resolved.Sep 6 2018, 10:01 AM
Antonio Vazquez (antoniov) claimed this task.
Ricardo Diaz (poyodiaz) added a comment.Sep 7 2018, 11:06 AM
hello , i am afraid is happening again, maybe is some kind of bug, the vertex is showing in other grease pencil objects, but in thethe one I have worked and draw more lines and spend more time is the one having this estrange behavior , again,I can't see the vertex in edit mode, I noted that when it happens; simultaneously I can not switch the grease pencil object to edit mode (is stuck in object mode) and I need to reload the file but I can't see the lines anyway even reloading.
thanks again
Ricardo Diaz (poyodiaz) added a comment.EditedSep 7 2018, 11:42 AM
sorry to bother with this again but I observed some particularities, it seems that the object in the file got corrupted ill try to explain
i have a previous hash version of 2.8 that doesn't makes this bug, after I had the bug problem I opened the file with it without luck, same behavior , but with the difference that grease pencil worked as expected ( no bug with new files or objects, only with the damaged object ) but, in the hash version that corrupted my file, grease pencil was still working wrong, no grease pencil vertex showing at all in edit mode, until I turned the Mac totally off and turned it on again, it was working as expected again(sadly my grease pencil animation remains with the bug, I am afraid it got damaged)
importing the grease pencil object in a fresh file doesn't help either, it remains corrupted
I hope this makes sense to you, I can send the blender file if needed
Antonio Vazquez (antoniov) added a comment.Sep 7 2018, 2:57 PM
I cannot reproduce your problem, so I need a file and exact steps to reproduce it. Without this info, it's impossible to find it (if there is something to fix).
If you have the problem with one file only, maybe this file is damaged for any reason (this is common when the program is changing every day as blender 2.8 does)
Ricardo Diaz (poyodiaz) added a comment.Sep 7 2018, 7:58 PM
This comment was removed by Ricardo Diaz (poyodiaz).
Ricardo Diaz (poyodiaz) added a comment.Sep 8 2018, 9:58 AM
found the problem, , the materials were locked, sorry again I feel so stupid
Antonio Vazquez (antoniov) added a comment.Sep 8 2018, 10:53 AM
No problem, so many things to learn that it's normal.
