Maniphest T56719
Crashing while adding objects + "Incorrect" scaling
Closed, Duplicate
None
Roci (Roci)
Sep 8 2018, 7:07 AM
  • BF Blender
  • BF Blender: 2.8
Antonio Vazquez (antoniov)
Bastien Montagne (mont29)
Roci (Roci)
OS: WIndows 10
CPU: Ryzen 2500U
GPU: Vega 8
RAM: 8GB
Broken: Blender 2.8 b8ac2379eb1
Worked: One of the older versions of Blender 2.8 (Roughly 2 weeks ago from now (8th September 2018))
Blender occasionally crashes when adding objects to the scene.
  1. Open a new scene.
  2. Add objects to the scene until the scene crashes. (It usually occurs when I delete the default cube then add a new one).
Scaling Issue:
I know it said not to report issues/bugs that aren't crashes, but I thought this one was worth including.
Objects don't scale along axis "correctly" while rotated and in Object mode.
This occurs with all sorts of models, I'll focus on the default cube for simplicity.
  1. Add a cube.
  2. Rotate the cube along the X axis by 45 degrees. (Works with any angle that isn't 0 degrees or a multiple of 90)
  3. Scale the cube along the Z axis.
  4. You will now notice that the cube isn't properly scaling along the Z axis but both the Z and Y axis. The results I'd expect are ones shown when scaling along the Z axis in edit mode.
Related Objects
Mentioned In
T56717: Repeatedly adding a cylinder to a scene causes a crash
Mentioned Here
rBb8ac2379eb19: Cleanup: remove redundant assignment
Roci (Roci) created this task.Sep 8 2018, 7:07 AM
Roci (Roci) updated the task description.Sep 8 2018, 7:10 AM
Roci (Roci) renamed this task from Crashing while adding objects + Incorrect scaling to Crashing while adding objects + "Incorrect" scaling.Sep 8 2018, 7:43 AM
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Sep 8 2018, 3:40 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
When we say 'one issue per report', it’s one issue per report, not two! Seriously… And second one is not a bug at all, you cannot get 'same result as in editmode', basic math (geometry) 101…
As for First point, cannot reproduce (tried adding like 50 objects of all kind, no issue). As requested in the guideline, we need precise specific steps and reproducible case to investigate, otherwise we cannot do much…
Bastien Montagne (mont29) closed this task as a duplicate of T56717: Repeatedly adding a cylinder to a scene causes a crash .
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).Sep 8 2018, 5:37 PM
Compiling and checking in windows.
