Maniphest T56741
Color Picker Value Bug
Closed, Resolved
Brecht Van Lommel (brecht)
Julien Kaspar (JulienKaspar)
Sep 10 2018, 2:46 PM
  • Code Quest
  • BF Blender
Bastien Montagne (mont29)
Sam Van Hulle (sam_vh)
Sergey Sharybin (sergey)
William Reynish (billreynish)
Broken: 0284392c489
When dragging the Value up to the brightest point in the color picker, the value goes beyond the maximum of 1 and instead up to 16.292.
The halfway point of Value on the color picker is also not 0.5 but instead 0.18.
There seems to be some conflict with the color picker graphic and the color correction in the editors.
Revisions and Commits
rB Blender
Related Objects
Mentioned Here
T39627: HSL color sliders acting funky
rB0284392c4892: Cleanup: More variables unused in release
Julien Kaspar (JulienKaspar) created this task.Sep 10 2018, 2:46 PM
Julien Kaspar (JulienKaspar) moved this task from Tasks to Spring Bugs on the Code Quest board.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Sep 10 2018, 2:59 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
I can't reproduce this one. Are you using the default color picker or did you change it in the user preferences? Are you just dragging the vertical value slider with the mouse?
This by design, the middle show 0.5 in display space which is about 0.18 in scene linear space. We could make it 0.5 in scene linear space but then darker colors will only have a little bit of space at the bottom of the slider.
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Sep 10 2018, 3:33 PM
I can reproduce it.
If you set the color picker to HSV, then move the V all the way to 1, and then return to RGB, the values are over 1 (16.2917, 16.2917, 16.2917).
Brecht Van Lommel (brecht) added a comment.Sep 10 2018, 3:37 PM
@Julien Kaspar (JulienKaspar), does the issue happen in the daily build from https://builder.blender.org/download for you?
If it doesn't, I think we need to upgrade OpenColorIO in the studio.
Julien Kaspar (JulienKaspar) added a comment.Sep 10 2018, 3:38 PM
@Brecht Van Lommel (brecht) All of the color picker types act out but the default only once you change the HSV sliders to the maximum.
I noticed that it does actually work as it should (mostly) for the HSV sliders but the RGB ones all act wrong.
These three don't match with the HSV values or the graphic color picker.
William Reynish (billreynish) added a comment.Sep 10 2018, 3:39 PM
I for one get the same bug with builds from builder.blender.org
Julien Kaspar (JulienKaspar) added a comment.Sep 10 2018, 3:40 PM
@Brecht Van Lommel (brecht) I am currently working with the latest compiled version of Blender 2.8.
Brecht Van Lommel (brecht) added a comment.Sep 10 2018, 3:45 PM
Right, I suspect this is happening due issues with an older version of OpenColorIO, which the Linux studio builds and macOS buildbot are still using. The Linux buildbot on the other hand was upgraded and so would not have the bug, if my theory is right.
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Sep 17 2018, 11:00 AM
@Julien Kaspar (JulienKaspar) did you try with a linux buildbot build? or did you update ocio in the studio already?
Julien Kaspar (JulienKaspar) added a comment.Sep 17 2018, 11:07 AM
@Bastien Montagne (mont29) I just update Blender with the buildbot. How can/should I update the OpenColorIO manually? Are you having the same issue?
Bastien Montagne (mont29) added a subscriber: Sergey Sharybin (sergey).Sep 17 2018, 11:22 AM
@Julien Kaspar (JulienKaspar) you downloaded blender from https://builder.blender.org/download ? Then you have nothing to do but try that blender and see if things work or not (just to be sure, buildbot has nothing to do with the build script you have at the studio ;) ).
Studio OCIO update is job for @Sergey Sharybin (sergey) or @Brecht Van Lommel (brecht)!
And no, here everything seems to work fine.
William Reynish (billreynish) added a comment.Sep 17 2018, 12:00 PM
It seems to work fine now on Mac after the libs were updated.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Sep 17 2018, 12:12 PM
We still need to update the libs in the studio, will be done soon. But seems no bug in Blender itself.
Sam Van Hulle (sam_vh) changed the task status from Resolved to Unknown Status.Dec 11 2018, 1:12 PM
Sam Van Hulle (sam_vh) added a subscriber: Sam Van Hulle (sam_vh).
Just wanted to report that this has been back for a few days. Current build with the problem is e4153946ad1.
Sergey Sharybin (sergey) added a comment.Dec 11 2018, 2:16 PM
This is weird. Studio sues OCIO 1.1.0, which is would guess is an updated version.
@Brecht Van Lommel (brecht), i guess this is due to the for for the default view transform of the display. Guess a view somewhere is to be initialized to IMB_colormanagement_init_default_view_settings.
Brecht Van Lommel (brecht) added a comment.Dec 11 2018, 2:26 PM
I think the bug is that the view transform is involved at all in HSV conversion, to me it seems HSV should be remain linear.
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed BF Blender: 2.8.Dec 11 2018, 3:10 PM
Sam Van Hulle (sam_vh) added a comment.Dec 11 2018, 4:12 PM
@Brecht Van Lommel (brecht) I would expect the same from the RGB values, no? Only involve the view transform in displaying the colours, not the numbers? I just assumed all of the values were always linear, and wherever I'd see an actual colour displayed, that would have been transformed. Or am I seeing things wrong?
Brecht Van Lommel (brecht) added a comment.Dec 11 2018, 7:57 PM
The RGB values are linear. I would also expect the view transform to be for displaying the colors only. It apparently was changed to fix T39627: HSL color sliders acting funky, but it seems like the wrong solution.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved by committing rB6601a89650f9: Fix T58549, T56741: HSV color picker issues with Filmic view transform..Dec 13 2018, 7:32 PM
Brecht Van Lommel (brecht) added a commit: rB6601a89650f9: Fix T58549, T56741: HSV color picker issues with Filmic view transform..
