Maniphest T56767
Manual instruction for installing on Linux is either wrong or needing update
Closed, Resolved
None
Hoang Duy Tran (hoangduytran)
Sep 11 2018, 11:39 PM
None
Reading the
https://docs.blender.org/manual/en/dev/getting_started/installing/linux.html
you'll find the line
KDE: System Settings ‣ Window Behavior ‣ Window Behavior ‣ Window Actions, Switch ‘Alt’ for ‘Meta’ key.
I switched to an installation of Mint 19, setup KDE and found the setting is as shown in the image:
This shows the KDE
System Settings > Windows Management > Window Behaviour > Window Actions
Revisions and Commits
rBM Blender Manual
Hoang Duy Tran (hoangduytran) created this task.Sep 11 2018, 11:39 PM
Hoang Duy Tran (hoangduytran) added a comment.Sep 11 2018, 11:41 PM
You might need to add change <Switch "Modifier key" from 'Alt' to 'Meta' for an absolute clear instruction>
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved by committing rBM4433: Fix T56767: wrong description of KDE modifier key changes..Sep 12 2018, 9:57 AM
Brecht Van Lommel (brecht) added a commit: rBM4433: Fix T56767: wrong description of KDE modifier key changes..
