Maniphest T56889
2.8 crashes in prefrences system
Closed, Resolved
Brecht Van Lommel (brecht)
Vince Herried (vince_549)
Sep 23 2018, 7:12 PM
  • BF Blender
noki paike (amonpaike)
Fedora 28 64 bbit
Radon hd7700 series.
blender-2.80-b350b194eb2-linux-glibc224-x86_64
When I go to Edit -> User Preferences -> System blender crashes instantly
Vince Herried (vince_549) created this task.Sep 23 2018, 7:12 PM
Vince Herried (vince_549) added a comment.Sep 23 2018, 7:29 PM
running glibc.x86_64 2.27-32.fc28
Kernel 4.18.9-200.fc28.x86_64
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Sep 24 2018, 8:53 AM
Brecht Van Lommel (brecht) mentioned this in T56890: Blender 2.79b x64 creashes on latest Fedor build ( f28 ).
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
  • Is there an error in the console, and if so can you attach it?
  • Can you attach the output of glxinfo?
  • Try running this and attach the output here:
gdb ./blender
run
(make it crash)
bt all
Vince Herried (vince_549) added a comment.Sep 24 2018, 3:49 PM
partial glxinfo:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: X.Org (0x1002)
Device: AMD CAPE VERDE (DRM 2.50.0 / 4.18.9-200.fc28.x86_64, LLVM 6.0.1) (0x6825)
Version: 18.0.5
Accelerated: yes
Video memory: 2048MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
Memory info (GL_ATI_meminfo):
VBO free memory - total: 2047 MB, largest block: 2047 MB
VBO free aux. memory - total: 2043 MB, largest block: 2043 MB
Texture free memory - total: 2047 MB, largest block: 2047 MB
Texture free aux. memory - total: 2043 MB, largest block: 2043 MB
Renderbuffer free memory - total: 2047 MB, largest block: 2047 MB
Renderbuffer free aux. memory - total: 2043 MB, largest block: 2043 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 2048 MB
Total available memory: 4091 MB
Currently available dedicated video memory: 2047 MB
OpenGL vendor string: X.Org
OpenGL renderer string: AMD CAPE VERDE (DRM 2.50.0 / 4.18.9-200.fc28.x86_64, LLVM 6.0.1)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.0.5
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
(gdb) run
Starting program: /home/vince/Downloads/blender-2.79b-linux-glibc219-x86_64/blender
Missing separate debuginfos, use: dnf debuginfo-install glibc-2.27-32.fc28.x86_64
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
warning: Loadable section ".note.gnu.property" outside of ELF segments
[New Thread 0x7ffff36d0700 (LWP 24352)]
[New Thread 0x7ffff2ecf700 (LWP 24353)]
[New Thread 0x7ffff26ce700 (LWP 24354)]
[New Thread 0x7ffff1ecd700 (LWP 24355)]
[New Thread 0x7fffe0762700 (LWP 24356)]
[Thread 0x7fffe0762700 (LWP 24356) exited]
[New Thread 0x7fffe0762700 (LWP 24357)]
[New Thread 0x7ffff7fbc700 (LWP 24358)]
[New Thread 0x7fffcfbff700 (LWP 24359)]
[Thread 0x7fffcfbff700 (LWP 24359) exited]
[New Thread 0x7fffc7bae700 (LWP 24360)]
[New Thread 0x7fffc6f92700 (LWP 24361)]
[New Thread 0x7fffc6791700 (LWP 24362)]
[New Thread 0x7fffc5f90700 (LWP 24363)]
[New Thread 0x7fffc578f700 (LWP 24364)]
[New Thread 0x7fffc4f8e700 (LWP 24365)]
[New Thread 0x7fffc478d700 (LWP 24366)]
[New Thread 0x7fffc39ff700 (LWP 24367)]
found bundled python: /home/vince/Downloads/blender-2.79b-linux-glibc219-x86_64/2.79/python
[New Thread 0x7fffbaed3700 (LWP 24370)]
[New Thread 0x7fffba6d2700 (LWP 24371)]
[New Thread 0x7fffb9ed1700 (LWP 24372)]
[New Thread 0x7fffb96d0700 (LWP 24373)]
[Thread 0x7fffb96d0700 (LWP 24373) exited]
[Thread 0x7fffb9ed1700 (LWP 24372) exited]
[Thread 0x7fffba6d2700 (LWP 24371) exited]
[Thread 0x7fffbaed3700 (LWP 24370) exited]
mesa: CommandLine Error: Option 'enable-value-profiling' registered more than once!
LLVM ERROR: inconsistency in registered CommandLine options
[Thread 0x7fffc39ff700 (LWP 24367) exited]
[Thread 0x7fffc478d700 (LWP 24366) exited]
[Thread 0x7fffc4f8e700 (LWP 24365) exited]
[Thread 0x7fffc6791700 (LWP 24362) exited]
[Thread 0x7fffc578f700 (LWP 24364) exited]
[Thread 0x7fffc5f90700 (LWP 24363) exited]
[Thread 0x7fffc6f92700 (LWP 24361) exited]
[Thread 0x7fffc7bae700 (LWP 24360) exited]
[Thread 0x7ffff7fbc700 (LWP 24358) exited]
[Thread 0x7fffe0762700 (LWP 24357) exited]
[Thread 0x7ffff1ecd700 (LWP 24355) exited]
[Thread 0x7ffff26ce700 (LWP 24354) exited]
[Thread 0x7ffff2ecf700 (LWP 24353) exited]
[Thread 0x7ffff36d0700 (LWP 24352) exited]
[Inferior 1 (process 24342) exited with code 01]
Missing separate debuginfos, use: dnf debuginfo-install SDL2-2.0.8-5.fc28.x86_64 beignet-1.3.2-2.fc28.x86_64 clang-libs-6.0.1-1.fc28.x86_64 clang5.0-libs-5.0.1-3.fc28.x86_64 dbus-libs-1.12.10-1.fc28.x86_64 elfutils-libelf-0.173-1.fc28.x86_64 expat-2.2.5-3.fc28.x86_64 flac-libs-1.3.2-7.fc28.x86_64 gsm-1.0.17-5.fc28.x86_64 hwloc-libs-1.11.9-1.fc28.x86_64 jack-audio-connection-kit-1.9.12-4.fc28.x86_64 libICE-1.0.9-12.fc28.x86_64 libSM-1.2.2-8.fc28.x86_64 libX11-1.6.5-7.fc28.x86_64 libX11-xcb-1.6.5-7.fc28.x86_64 libXau-1.0.8-11.fc28.x86_64 libXcursor-1.1.15-1.fc28.x86_64 libXdamage-1.1.4-12.fc28.x86_64 libXext-1.3.3-8.fc28.x86_64 libXfixes-5.0.3-5.fc28.x86_64 libXi-1.7.9-6.fc28.x86_64 libXrender-0.9.10-5.fc28.x86_64 libXtst-1.2.3-5.fc28.x86_64 libXxf86vm-1.1.4-7.fc28.x86_64 libasyncns-0.8-14.fc28.x86_64 libblkid-2.32.1-1.fc28.x86_64 libcap-2.25-9.fc28.x86_64 libdrm-2.4.93-1.fc28.x86_64 libedit-3.1-23.20170329cvs.fc28.x86_64 libffi-3.1-16.fc28.x86_64 libgcc-8.1.1-5.fc28.x86_64 libgcrypt-1.8.3-1.fc28.x86_64 libglvnd-1.1.0-1.fc28.x86_64 libglvnd-egl-1.1.0-1.fc28.x86_64 libglvnd-glx-1.1.0-1.fc28.x86_64 libgpg-error-1.31-1.fc28.x86_64 libmount-2.32.1-1.fc28.x86_64 libogg-1.3.2-10.fc28.x86_64 libpciaccess-0.13.4-8.fc28.x86_64 libselinux-2.8-1.fc28.x86_64 libsndfile-1.0.28-7.fc28.x86_64 libstdc++-8.1.1-5.fc28.x86_64 libtool-ltdl-2.4.6-24.fc28.x86_64 libuuid-2.32.1-1.fc28.x86_64 libvorbis-1.3.6-3.fc28.x86_64 libxcb-1.13-1.fc28.x86_64 libxshmfence-1.3-1.fc28.x86_64 llvm-libs-6.0.1-7.fc28.x86_64 llvm5.0-libs-5.0.1-7.fc28.x86_64 lz4-libs-1.8.1.2-4.fc28.x86_64 mesa-dri-drivers-18.0.5-4.fc28.x86_64 mesa-libGL-18.0.5-4.fc28.x86_64 mesa-libGLU-9.0.0-14.fc28.x86_64 mesa-libOpenCL-18.0.5-4.fc28.x86_64 mesa-libglapi-18.0.5-4.fc28.x86_64 ncurses-libs-6.1-5.20180224.fc28.x86_64 numactl-libs-2.0.11-8.fc28.x86_64 ocl-icd-2.2.12-1.fc28.x86_64 opus-1.3-0.7.rc2.fc28.x86_64 pcre2-10.31-11.fc28.x86_64 pocl-1.1-4.fc28.x86_64 pulseaudio-libs-12.2-1.fc28.x86_64 sssd-client-1.16.3-2.fc28.x86_64 systemd-libs-238-9.git0e0aa59.fc28.x86_64 xz-libs-5.2.4-2.fc28.x86_64 zlib-1.2.11-8.fc28.x86_64
(gdb)
(gdb) bt all
No stack.
(gdb)
Vince Herried (vince_549) added a comment.Sep 24 2018, 3:55 PM
dang I'm having trouble navigating this error reporting system. Sorry. So here is output from debug of 2.8
(gdb) run
Starting program: /home/vince/Downloads/blender-2.80-b350b194eb2-linux-glibc224-x86_64/blender
[New Thread 0x7ffff38be700 (LWP 24434)]
[New Thread 0x7ffff30bd700 (LWP 24435)]
[New Thread 0x7ffff28bc700 (LWP 24436)]
[New Thread 0x7ffff20bb700 (LWP 24437)]
[New Thread 0x7ffff7fbb700 (LWP 24438)]
[Thread 0x7ffff7fbb700 (LWP 24438) exited]
[New Thread 0x7fffdff11700 (LWP 24439)]
[New Thread 0x7fffdff11700 (LWP 24440)]
[Thread 0x7fffdff11700 (LWP 24439) exited]
[New Thread 0x7fffcf710700 (LWP 24441)]
[New Thread 0x7fffc72be700 (LWP 24442)]
[New Thread 0x7fffc6561700 (LWP 24443)]
[New Thread 0x7fffc5d60700 (LWP 24444)]
[New Thread 0x7fffc555f700 (LWP 24445)]
[New Thread 0x7fffc4d5e700 (LWP 24446)]
[New Thread 0x7fffc455d700 (LWP 24447)]
[New Thread 0x7fffc3d5c700 (LWP 24448)]
[New Thread 0x7fffc3350700 (LWP 24449)]
Warning: Could not find a matching GPU name. Things may not behave as expected.
[New Thread 0x7fffc1f4f700 (LWP 24450)]
[New Thread 0x7fffc174e700 (LWP 24451)]
[New Thread 0x7fffc0f4d700 (LWP 24452)]
[New Thread 0x7fffbf54c700 (LWP 24453)]
found bundled python: /home/vince/Downloads/blender-2.80-b350b194eb2-linux-glibc224-x86_64/2.80/python
WARNING! Using this helper function is deprecated, please switch to orientation_helper decorator instead.
[New Thread 0x7fffb9f9b700 (LWP 24462)]
[New Thread 0x7fffb332f700 (LWP 24463)]
[New Thread 0x7fffb2b2e700 (LWP 24464)]
[New Thread 0x7fffb232d700 (LWP 24465)]
[New Thread 0x7fffb1b2c700 (LWP 24466)]
[Thread 0x7fffb232d700 (LWP 24465) exited]
[Thread 0x7fffb2b2e700 (LWP 24464) exited]
[Thread 0x7fffb332f700 (LWP 24463) exited]
[Thread 0x7fffb1b2c700 (LWP 24466) exited]
[Thread 0x7fffb9f9b700 (LWP 24462) exited]
[Thread 0x7fffbf54c700 (LWP 24453) exited]
[Thread 0x7fffc3350700 (LWP 24449) exited]
[Thread 0x7fffc3d5c700 (LWP 24448) exited]
[Thread 0x7fffc455d700 (LWP 24447) exited]
[Thread 0x7fffc5d60700 (LWP 24444) exited]
[Thread 0x7fffc4d5e700 (LWP 24446) exited]
[Thread 0x7fffc555f700 (LWP 24445) exited]
[Thread 0x7fffc6561700 (LWP 24443) exited]
[Thread 0x7fffc72be700 (LWP 24442) exited]
[Thread 0x7fffcf710700 (LWP 24441) exited]
[Thread 0x7fffdff11700 (LWP 24440) exited]
[Thread 0x7ffff20bb700 (LWP 24437) exited]
[Thread 0x7ffff30bd700 (LWP 24435) exited]
[Thread 0x7ffff28bc700 (LWP 24436) exited]
[Thread 0x7ffff38be700 (LWP 24434) exited]
[Thread 0x7fffc174e700 (LWP 24451) exited]
[Thread 0x7fffc1f4f700 (LWP 24450) exited]
[Thread 0x7ffff7fbdfc0 (LWP 24424) exited]
[Inferior 1 (process 24424) exited with code 01]
Missing separate debuginfos, use: dnf debuginfo-install SDL2-2.0.8-5.fc28.x86_64 beignet-1.3.2-2.fc28.x86_64 clang-libs-6.0.1-1.fc28.x86_64 clang5.0-libs-5.0.1-3.fc28.x86_64 dbus-libs-1.12.10-1.fc28.x86_64 elfutils-libelf-0.173-1.fc28.x86_64 expat-2.2.5-3.fc28.x86_64 flac-libs-1.3.2-7.fc28.x86_64 gsm-1.0.17-5.fc28.x86_64 hwloc-libs-1.11.9-1.fc28.x86_64 jack-audio-connection-kit-1.9.12-4.fc28.x86_64 libICE-1.0.9-12.fc28.x86_64 libSM-1.2.2-8.fc28.x86_64 libX11-1.6.5-7.fc28.x86_64 libX11-xcb-1.6.5-7.fc28.x86_64 libXau-1.0.8-11.fc28.x86_64 libXcursor-1.1.15-1.fc28.x86_64 libXdamage-1.1.4-12.fc28.x86_64 libXext-1.3.3-8.fc28.x86_64 libXfixes-5.0.3-5.fc28.x86_64 libXi-1.7.9-6.fc28.x86_64 libXrender-0.9.10-5.fc28.x86_64 libXtst-1.2.3-5.fc28.x86_64 libXxf86vm-1.1.4-7.fc28.x86_64 libasyncns-0.8-14.fc28.x86_64 libblkid-2.32.1-1.fc28.x86_64 libcap-2.25-9.fc28.x86_64 libdrm-2.4.93-1.fc28.x86_64 libedit-3.1-23.20170329cvs.fc28.x86_64 libffi-3.1-16.fc28.x86_64 libgcc-8.1.1-5.fc28.x86_64 libgcrypt-1.8.3-1.fc28.x86_64 libglvnd-1.1.0-1.fc28.x86_64 libglvnd-egl-1.1.0-1.fc28.x86_64 libglvnd-glx-1.1.0-1.fc28.x86_64 libgpg-error-1.31-1.fc28.x86_64 libmount-2.32.1-1.fc28.x86_64 libogg-1.3.2-10.fc28.x86_64 libpciaccess-0.13.4-8.fc28.x86_64 libselinux-2.8-1.fc28.x86_64 libsndfile-1.0.28-7.fc28.x86_64 libstdc++-8.1.1-5.fc28.x86_64 libtool-ltdl-2.4.6-24.fc28.x86_64 libuuid-2.32.1-1.fc28.x86_64 libvorbis-1.3.6-3.fc28.x86_64 libxcb-1.13-1.fc28.x86_64 libxshmfence-1.3-1.fc28.x86_64 llvm-libs-6.0.1-7.fc28.x86_64 llvm5.0-libs-5.0.1-7.fc28.x86_64 lz4-libs-1.8.1.2-4.fc28.x86_64 mesa-dri-drivers-18.0.5-4.fc28.x86_64 mesa-libGL-18.0.5-4.fc28.x86_64 mesa-libOpenCL-18.0.5-4.fc28.x86_64 mesa-libglapi-18.0.5-4.fc28.x86_64 ncurses-libs-6.1-5.20180224.fc28.x86_64 numactl-libs-2.0.11-8.fc28.x86_64 ocl-icd-2.2.12-1.fc28.x86_64 opus-1.3-0.7.rc2.fc28.x86_64 pcre2-10.31-11.fc28.x86_64 pocl-1.1-4.fc28.x86_64 pulseaudio-libs-12.2-1.fc28.x86_64 sssd-client-1.16.3-2.fc28.x86_64 systemd-libs-238-9.git0e0aa59.fc28.x86_64 xz-libs-5.2.4-2.fc28.x86_64 zlib-1.2.11-8.fc28.x86_64
(gdb)
again no stack.
Do you need me to install the debuginfo ???
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Sep 24 2018, 3:59 PM
The critical line is this:
It's not a bug in Blender, but in the system OpenCL implementation. The workaround is to uninstall the beignet and pocl OpenCL packages. For more info:
https://bugzilla.redhat.com/show_bug.cgi?id=1565659
https://lists.blender.org/pipermail/bf-committers/2018-April/049325.html
Vince Herried (vince_549) added a comment.Sep 24 2018, 4:07 PM
Wow super quick response. That seemed to fix both problems thanks grazzie ( I'm trying to learn Italian :)
noki paike (amonpaike) added a subscriber: noki paike (amonpaike).Sep 24 2018, 4:10 PM
"Grazie" con una sola Z ^_____^
Vince Herried (vince_549) changed the task status from Unknown Status to Resolved.Sep 24 2018, 4:35 PM
Brecht Van Lommel (brecht) mentioned this in T56995: blender 2.8 crashes.Oct 2 2018, 1:35 AM
