Maniphest T56897
Smoke Simulation Memory Leak on Linux
Closed, Resolved
ronald engel (ronald8e)
Sep 24 2018, 11:19 AM
  • BF Blender
  • Physics
Bastien Montagne (mont29)
Brecht Van Lommel (brecht)
Ubuntu 17.10 64bit
Broken: Ubuntu 2.79.6 64bit, build 23.9.2018
Worked: Windows 2.79.6 64 bit, build around 6.9.2018
Worked too with 2.79b official builds
Baking Smoke simulation fills RAM and swap file then crashes on linux. Works under windows.
Reproduce: Just bake smoke sim in attached .blend file.
ronald engel (ronald8e) created this task.Sep 24 2018, 11:19 AM
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Sep 30 2018, 6:49 PM
Bastien Montagne (mont29) added a project: Physics.
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
There is no memory leak detected by ASAN, but can confirm it does take a huge amount of RAM very quickly here (just two or three simulated frames at start of baking are enough to fill up my 10GB free RAM…). Then the simulation is a very heavy one, so no idea (or ways to compare with Windows) here. Have the same results with Debian’s 2.79b package, though.
ronald engel (ronald8e) added a comment.Oct 1 2018, 12:32 PM
Under Windows 10 RAM usage stays below 15 GB (around 9-12 if I remember it correctly). In ubuntu 17.10 it never stops filling RAM and swap file. Can't do any further tests though since I'm not at work the next two weeks.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).EditedOct 3 2018, 12:18 PM
This might be the same as T54287, please try with tomorrow's daily build or a newer version to verify if it's solved.
ronald engel (ronald8e) changed the task status from Unknown Status to Resolved.Oct 15 2018, 9:54 AM
ronald engel (ronald8e) claimed this task.
Tested it with yesterdays build. RAM usage stays below 12 GB on a 32 GB system. It no longer fills up RAM and swap file.
Thank you!
