Maniphest T56949
Pie menu design improvements
Confirmed, NormalDESIGN
None
William Reynish (billreynish)
Sep 28 2018, 4:18 PM
  • BF Blender: 2.8
  • User Interface
Alexey (Lexi4)
Brecht Van Lommel (brecht)
Chris Kohl (ckohl_art)
Don Hopkins (SimHacker)
Duarte Farrajota Ramos (duarteframos)
Jan Vetulani (jasiuek)
9 More Subscribers
Tokens
"Love" token, awarded by hadrien."Love" token, awarded by Shimoon."Love" token, awarded by temeddix."Love" token, awarded by Tetone."Love" token, awarded by bnzs."Like" token, awarded by duarteframos."Love" token, awarded by sebastianmroy."Like" token, awarded by 0o00o0oo."Love" token, awarded by xrg."Like" token, awarded by plundh.
Now that we are adding more pie menus, we could make some small but effective improvements to them.
Wedge Highlighting
First, the wedge could be highlighted as you rollover it, to make it clearer how big the area is, like so:
Holding, Then Releasing Key Should Always Dismiss Pie
There's a slight quirk in the way we handle input: Normally, if you hold a key to invoke a pie menu and then let go, the pie menu is dismissed. This works if you move your cursor to an item, or to an empty area. But, if you don't move the cursor at all, this doesn't work. This makes the behaviour inconsistent, and makes the pies 'stick' in an annoying way if you regret opening one.
Letter Input While Pie is Active
While number input works reasonably well, in Blender we also use letters to invoke options in menus. For pies, letters work better, because the order makes less direct sense. There's nothing intuitive that says left=1, right=2, and so on. We should enable letter input to activate pie options. This way, user can press Z, S to activate Solid Mode.
These three changes should make pie menus more delightful to use.
Related Objects
William Reynish (billreynish) lowered the priority of this task from 90 to Normal.Sep 28 2018, 4:18 PM
William Reynish (billreynish) created this task.
William Reynish (billreynish) added a project: User Interface.Sep 28 2018, 4:28 PM
William Reynish (billreynish) updated the task description.
William Reynish (billreynish) updated the task description.Sep 28 2018, 4:39 PM
William Reynish (billreynish) updated the task description.Sep 28 2018, 4:51 PM
Petter Lundh (plundh) awarded a token.Sep 30 2018, 10:08 AM
Petter Lundh (plundh) added a subscriber: Petter Lundh (plundh).
xrg (xrg) awarded a token.Sep 30 2018, 4:56 PM
Oscar (KINjO) added a subscriber: Oscar (KINjO).Oct 1 2018, 10:54 AM
KiJeon (0o00o0oo) awarded a token.Oct 1 2018, 11:15 AM
KiJeon (0o00o0oo) added a subscriber: KiJeon (0o00o0oo).
KiJeon (0o00o0oo) added a comment.Oct 1 2018, 11:20 AM
Is this task meant for improvements in general to the pie menu, or just these specific proposed changes?
William Reynish (billreynish) added a comment.Oct 1 2018, 12:04 PM
KiJeon: What do you mean?
Tomas (Rusculleda) added a subscriber: Tomas (Rusculleda).Oct 1 2018, 2:11 PM
Small suggestion in regards to the pivot point pie menu. I think the two most used pivot point settings are "median point" (the default one) and "3d cursor" so it would make things faster if they were on opposing sides, and "active element" is, I think, much more often used than "bounding box center", so it would be nice if it was placed on one of the main directions, opposing "individual origins".
William Reynish (billreynish) updated the task description.Oct 1 2018, 4:29 PM
Pie menu active state was fixed by commit: c234c3db1bcb
Campbell Barton (campbellbarton) updated the task description.Oct 2 2018, 12:15 AM
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).EditedOct 2 2018, 1:09 AM
@William Reynish (billreynish), could you report an issue for remaining Pie menu glitches?
KiJeon (0o00o0oo) added a comment.Oct 2 2018, 4:36 AM
@William Reynish (billreynish) I mean is this task open to discussions on how to improve the pie menu in general, or meant only to discuss the specific items you outlined in the Description above?
I ask because the title seems to indicate the former, but if the intent is latter, I don't want to add noise to the discussion.
William Reynish (billreynish) added a comment.Oct 2 2018, 11:16 AM
Campbell: You are right. Will do.
KiJeon: You are welcome to suggest or point out something that could work better or differently.
Stig Olavsen (steego) added a subscriber: Stig Olavsen (steego).Oct 2 2018, 6:15 PM
However, the numbering order is scrambled. It doesn't follow the order of the actual items, which is left=1, right=2, top=3, bottom=4, and so on.
It's not scrambled, the layout follows that of the numpad if I'm not mistaken?
William Reynish (billreynish) added a comment.EditedOct 2 2018, 9:51 PM
Stig: You are right. Removed this section.
William Reynish (billreynish) updated the task description.Oct 2 2018, 9:51 PM
Sebastian M Roy (sebastianmroy) awarded a token.Nov 25 2018, 3:52 PM
Justin Jones (jjones780) added a subscriber: Justin Jones (jjones780).EditedJan 8 2019, 8:27 AM
Fix for: Holding, Then Releasing Key Should Always Dismiss Pie
I believe this fix complies with the intended behaviour of the pie menu as per the discussion at devtalk
I'm attaching a diff that adds a "Tap Key Timeout" setting to the Pie Menu preferences. It changes these files:
release/scripts/startup/bl_ui/space_userpref.py
source/blender/blenloader/ versioning_userdef.c
source/blender/editors/interface/interface_handlers.c
source/blender/makesdna/DNA_userdef_types.h
source/blender/makesrna/intern/rna_userdef.c
OR Instead of the diff... try it out with a hardcoded value of 20 by changing one line in interface_handlers.c:
+++ b/source/blender/editors/interface/interface_handlers.c
@@ -9405,7 +9405,7 @@ static int ui_pie_handler(bContext *C, const wmEvent *event, uiPopupBlockHandle
                        else {
                                /* distance from initial point */
-                               if (!(block->pie_data.flags & UI_PIE_DRAG_STYLE)) {
+                               if ((duration < 0.01 * 20  ) && !(block->pie_data.flags & UI_PIE_DRAG_STYLE)) {
                                        block->pie_data.flags |= UI_PIE_CLICK_STYLE;
                                else {
I submitted a proper diff here:
https://developer.blender.org/D4180
Sorry for all the noise.. learning the system.
zebus3d (ofuscado) added a subscriber: zebus3d (ofuscado).Jan 8 2019, 10:36 AM
Justin Jones (jjones780) added a comment.Jan 17 2019, 10:19 AM
D4220: Action With Second Press of Pie Shortcut Key
I've been trying out another change and have made a patch here
My first experience with Pie menus I expected to be able to toggle them away with the same key I used to bring them up and was slightly annoyed when that didn't occur. This patch also allows you to activate items with this key ( after a mouse move ). Essentially it acts as a mouse click.
I also felt ( not so strongly) that pressing the middle '5' key on the numeric keypad should act as if you clicked in the middle... i.e. dismiss it.
I expect a reviewer to request this be separated out into a second patch but have left it in for testing.
Issues:
If the pie is called up with a letter and no modifier then you will not be able to access a shortcut in the menu using that letter. This isn't an issue for modified key codes such as Shift-S. If it's a concern a preferences setting could allow the user to disable this or maybe change the shortcut to a shifted version.
Justin Jones (jjones780) added a comment.Jan 17 2019, 11:05 AM
Default Pie Menu Action.
Also... I'm experimenting on ways to allow the short 'tap' of a pie-menu key to perform an action ( instead of sticking the pie menu ).
For example, z held down brings up the Shading Pie menu however tapping it would simply toggle wireframe mode.
With the patch in my last post ( action with second press of pie shortcut key ) you can assign a double-click key action to a pie-menu key and have it occur when you activate and dismiss a pie menu with two quick taps. A preferences setting could modify this so that the double press action occurs for pie menus when a single short tap occurs.
Justin Jones (jjones780) added a comment.Jan 17 2019, 11:09 AM
Complex Pie Menus for testing?
Are there any test pie menus hidden away... something involving pie menus with inner block menus/pie menus etc?
Brecht Van Lommel (brecht) added subscribers: Julian Eisel (Severin), Brecht Van Lommel (brecht).Jan 17 2019, 8:05 PM
That seems reasonable. The conflict with shortcuts for items I guess can be avoided by consider that key as already taken so it users a different one.
We tried this for tab and edit mode switching, but found it does not work well. Many users multitask and move their mouse while pressing shortcut keys, and so accidentally trigger the pie menu.
Not that I'm aware, maybe @Julian Eisel (Severin) knows.
William Reynish (billreynish) added a comment.Jan 17 2019, 8:25 PM
I can answer this. There aren't any 'complex' pie menus in the default Blender pie menus. We decided against this for now, as they go against the main advantage of pie menus, which is the speedy, gestural input.
However, I believe there are some more advanced ones inside the pie menus addon, and there's also the Pie Menu Editor addon that allows users to build very complicated custom things.
Justin Jones (jjones780) added a comment.Jan 28 2019, 12:23 PM
I cleaned up my original diff and added an Interface->Pie Menus preferences entry "Pie Key Again Click" - "Pressing pie shortcut again will act as click ( to cancel or select )" which defaults to enabled.
Still diff D4220
I tried it with some of the pie menu add-ons: works well with submenus.
Duarte Farrajota Ramos (duarteframos) awarded a token.Jan 28 2019, 12:49 PM
Duarte Farrajota Ramos (duarteframos) added a subscriber: Duarte Farrajota Ramos (duarteframos).
Don Hopkins (SimHacker) added a subscriber: Don Hopkins (SimHacker).Mar 12 2019, 4:14 AM
Jan Vetulani (jasiuek) added a subscriber: Jan Vetulani (jasiuek).May 25 2019, 2:20 PM
Is there currently a way to re-arrange the Pie-Menus from the side of the user?
For instance the horizontal axis for the most used items is completely wrong for me, and I'd like to have them on a vertical one - so for instance the a TAB pie menu would have Object mode up top and Edit mode on the bottom.
Or at least provide us with a settings option to change them from a horizontal layout for most used items to a vertical one.
I like the tab pie menu but I'm one of the people who move their mouse a lot when pressing tab - so I constantly go into vertex paint when I just want to exit from Edit mode to Object mode with a single tab press.
Increasing the time needed to hold the tab before we can move the mouse to enter a pie menu would be cool too.
Campbell Barton (campbellbarton) mentioned this in T63726: User Interface Module .May 27 2019, 5:37 AM
B (bnzs) awarded a token.Aug 26 2019, 8:56 PM
stefano severi (Tetone) awarded a token.Sep 15 2019, 9:01 AM
Keenan (blenderartist18) added a subscriber: Keenan (blenderartist18).EditedSep 27 2019, 7:19 PM
I hope I'm not putting this in the wrong place. But I have a feature suggestion for pie menu.
It could be helpful if pie menu had sub-pie menus. For example a default sculpt brush could be the main selection, but the same brush with modifications could be a sub-pie menu.
Or, in general for say properties window. Sub-pie menus could descend into setting those properties, where finally the relevant setting widget would pop-up in the pie menu and be ready for manipulation by the activating device. dyntopo properties would be a breeze with this kind of set-up.
This type of set-up would create the fastest way to manipulate widgets, because it uses the least amount of pixel real estate to make those changes. It would be second place for speed to a hotkey.
Seb (Daxter753) added a subscriber: Seb (Daxter753).Oct 18 2019, 8:57 AM
Sorry but I want to swap where edit mode and object mode are but I don't know how.
If you do respond thanks in advance.
Dong-Hyun Kim (temeddix) awarded a token.May 1 2020, 3:41 PM
Chris Kohl (ckohl_art) added a subscriber: Chris Kohl (ckohl_art).May 15 2020, 10:17 AM
Simon (Shimoon) awarded a token.Jun 4 2020, 3:25 PM
Campbell Barton (campbellbarton) moved this task from Backlog to UI Redesigns on the User Interface board.Jun 18 2020, 8:50 AM
Julian Eisel (Severin) renamed this task from Blender 2.8: Pie menu improvements to Pie menu desgin improvements.Jun 26 2020, 7:10 PM
Julian Eisel (Severin) renamed this task from Pie menu desgin improvements to Pie menu design improvements.
Julian Eisel (Severin) moved this task from UI Redesigns to Short-Term Scope (Inactive) on the User Interface board.
Alexey (Lexi4) added a subscriber: Alexey (Lexi4).Jun 27 2020, 1:03 AM
Justin Jones (jjones780) added a comment.Jun 28 2020, 12:42 AM
Remove Issue? "Holding, Then Releasing Key Should Always Dismiss Pie" - This mentions the menu sticking open if the mouse isn't moved... I cannot replicate this behaviour. The pie menu will activate/cancel if menu key released.
Note the "Tap Key Timeout" preferences setting. Interface->Menus->Pie Menus controls how short a keypress will cause the menu to stick open ( 0 for never, defaults is 20/100s ).
Consider changing the issue to: " Dismiss Pie Menu with Second Press of Pie Menu shortcut Key"
Once stuck open the pie menu needs to be closed with a mouse click. Patch D4220 allows you to close it with another press of the key.
Tomas (Rusculleda) removed a subscriber: Tomas (Rusculleda).Jun 28 2020, 12:44 AM
Hadrien Brissaud (hadrien) awarded a token.Feb 23 2022, 1:36 PM
