OSX 10.14
Broken: Daily Builds
Worked: Release
After opening a blend file with text on curves, blender 2.8 crashes (NOT duplicate of fixed error T56879)
- Factory Defaults
- remove cube
- Create Bezier Circle
- Create Text
- Assign Bezier Circle to Text "Text on Curve Transform"
- Go into EDIT mode to see the text wrapped around curve
- Go into OBJECT mode
- rotate text on z axis (don't know if this is needed)
- SAVE file
- QUIT blender
- START blender
- OPEN file
- Right click text to select it
- Crash (not always, sometimes takes several edits/saves/open)
I've been trying to reproduce this consistently, but it doesn't always produce a crash right away. Sometimes it takes a couple of edits/saves/reopening to get blender to crash. Or it has something to do with the rotation or what object is selected during save. I can't tell for sure. Did my best ;-)
But I've attached a very simple scene where you only have to open it and rightclick to select the text to observe the crash. Maybe by analyzing that file you can find the exact reason why.
