Maniphest T57111
Particle texture keyframes missing from Graph Editor unless PS has keyframes
Closed, ResolvedBUG
Sybren A. Stüvel (sybren)
Georg K (georg)
Oct 9 2018, 1:56 AM
  • BF Blender
  • Animation & Rigging
Georg K (georg)
Philipp Oeser (lichtwerk)
Tokens
"Love" token, awarded by georg.
Ubuntu 18.04 x64, Radeon HD7770
Broken: 2.79b, blender-2.79-4b0b91aee07-linux-glibc219-x86_64, 2.80 Alpha2 hash cc92d83d398
Worked: ?
Can't view/edit particle texture keyframes (e.g. Clouds: NoiseSize/Colors/ImageMapping/ImageSampling, Blend: Colors, Blend, Distorted Noise: Colors, Distorted Noise, etc. ...) without a trick in 2.79.
Influence/Mapping properties of particle texture always seem to work (setting a keyframe there can also help showing the invisible keyframes).
In the default scene with the cube selected,
switch main window to Graph editor
go to particles tab in properties editor,
add a particle texture
go to texture properties
press I to add a keyframe to any property (not Influence/Mapping)
In the Graph editor, it is not displayed.
Now in 2.79x, if I add a keyframe on a particle system property (or particle texture Influence/Mapping property), the texture keyframes will be displayed in the Graph editor and they remain visible even after deleting this "helper keyframe". Also keeps working after saving/closing blender/reopening the file.
But in 2.80, the "helper keyframe" trick does not work. While the keyframes are visible in the graph editor without that trick, there is only the higher-level channel "Particle settings" but the subchannel Texture and the appropriate properties channels (with the eye buttons) are missing, so if there are keyframes on multiple properties you won't know which is which.
Revisions and Commits
rB Blender
Georg K (georg) created this task.Oct 9 2018, 1:56 AM
Philipp Oeser (lichtwerk) claimed this task.Oct 9 2018, 2:05 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.
Can confirm this, will have a look...
Philipp Oeser (lichtwerk) added a comment.Apr 8 2019, 8:49 PM
At least that seems to have improved since, so the 2.79 trick seems to work now.
Rest still holds true though.
Philipp Oeser (lichtwerk) removed Philipp Oeser (lichtwerk) as the assignee of this task.Nov 12 2019, 2:42 PM
Philipp Oeser (lichtwerk) added projects: User Interface, Animation & Rigging.
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:35 PM
Sybren A. Stüvel (sybren) claimed this task.Jan 2 2020, 6:13 PM
Sybren A. Stüvel (sybren) changed the subtype of this task from "Report" to "Bug".
Sybren A. Stüvel (sybren) removed projects: Tracker Curfew, User Interface.
Sybren A. Stüvel (sybren) closed this task as Resolved by committing rBa854840e76ae: Fix T57111: Particle texture keyframes missing from Graph Editor.Jan 2 2020, 6:15 PM
Sybren A. Stüvel (sybren) added a commit: rBa854840e76ae: Fix T57111: Particle texture keyframes missing from Graph Editor.
Georg K (georg) awarded a token.Jan 3 2020, 6:15 PM
