Testing the nightly build for 2.8 on an AWS server with Ubuntu 18.04, I get the following reported CPU and GPU:
Found device: Intel Core i7-6950X CPU @ 3.00GHz
<bpy_struct, CyclesDeviceSettings("Intel Core i7-6950X CPU @ 3.00GHz")>
Found device: GeForce GTX 1080
<bpy_struct, CyclesDeviceSettings("GeForce GTX 1080")>The real GPU cards on the server are different, as reported by nvidia-smi:
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 410.48 Driver Version: 410.48 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | |===============================+======================+======================| | 0 GRID K520 Off | 00000000:00:03.0 Off | N/A | | N/A 29C P0 44W / 125W | 0MiB / 4037MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 1 GRID K520 Off | 00000000:00:04.0 Off | N/A | | N/A 33C P0 43W / 125W | 0MiB / 4037MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 2 GRID K520 Off | 00000000:00:05.0 Off | N/A | | N/A 31C P0 44W / 125W | 0MiB / 4037MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 3 GRID K520 Off | 00000000:00:06.0 Off | N/A | | N/A 32C P0 38W / 125W | 0MiB / 4037MiB | 0% Default | +-------------------------------+----------------------+----------------------+
The processor reported (truncated from /proc/cpuinfo):
processor : 31 vendor_id : GenuineIntel cpu family : 6 model : 62 model name : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz stepping : 4 microcode : 0x42c cpu MHz : 2593.805 cache size : 20480 KB physical id : 1 siblings : 16 core id : 7 cpu cores : 8 apicid : 47 initial apicid : 47 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm constant_tsc rep_good nopl xtopology cpuid pni pclmulqdq ssse3 cx16 pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm cpuid_fault pti fsgsbase smep erms xsaveopt bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf bogomips : 5187.66 clflush size : 64 cache_alignment : 64 address sizes : 46 bits physical, 48 bits virtual
We also tested on different server configurations under linux and found the same GPU reported, even though the server had 4 K80 cards in it.
The render time is also off, the same render takes 5 times longer than 2.79 on the same server (same file, same resolution nas sampling settings). It looks like the GPU is not used at all, according to nvidia-smi.
Let me know if you need any other information to sort this out.
