Maniphest T57331
evee renders the basic cube wronge
Closed, Duplicate
Clément Foucault (fclem)
Mathieu Dijkstra (x_mtd_x)
Oct 21 2018, 10:17 AM
  • BF Blender: 2.8
  • EEVEE & Viewport
Christopher_Anderssarian
Philipp Oeser (lichtwerk)
the other modes work fine only eevee dos not work coreckt (games have no problem some where there is a fault in the engine for my gpu)
some how eevee renders the cube wrong at my computer.
old versions works fine???
if i set the output to 4k DCi 2160p i get this:
here is the debug on 23 still wronge output:
Mathieu Dijkstra (x_mtd_x) created this task.Oct 21 2018, 10:17 AM
Mathieu Dijkstra (x_mtd_x) added a project: BF Blender: 2.8.Oct 21 2018, 10:20 AM
Mathieu Dijkstra (x_mtd_x) updated the task description.Oct 21 2018, 10:39 AM
Philipp Oeser (lichtwerk) assigned this task to Clément Foucault (fclem).Oct 22 2018, 12:50 PM
Philipp Oeser (lichtwerk) added subscribers: Clément Foucault (fclem), Philipp Oeser (lichtwerk).
@Clément Foucault (fclem): mind having a look?
Mathieu Dijkstra (x_mtd_x) updated the task description.Oct 22 2018, 3:28 PM
Clément Foucault (fclem) added a comment.Oct 22 2018, 6:11 PM
@Mathieu Dijkstra (x_mtd_x) does that happen with latest build?
Mathieu Dijkstra (x_mtd_x) added a comment.EditedOct 22 2018, 8:29 PM
i dont know
i wil check wat buld do you say i need to check (can you aply a link to a 64bit windows build zip?)
Christopher_Anderssarian removed a project: BF Blender.Oct 22 2018, 10:16 PM
Christopher_Anderssarian added a subscriber: Christopher_Anderssarian.
Here are the Daily Builds: https://builder.blender.org/download/
Mathieu Dijkstra (x_mtd_x) added a comment.EditedOct 23 2018, 9:48 AM
no the daily build is same problem in the render function in eevee (olther modes work fine in this build opengl and cycles only problem is the eevee engine build)(F12) :
{{F5195380}F5195276}
other modes
cycles
opengl
Clément Foucault (fclem) mentioned this in T56668: Intel HD530 + Windows 10 Bugs.Oct 23 2018, 2:43 PM
Clément Foucault (fclem) added a comment.Oct 23 2018, 6:09 PM
This is caused by another driver bug. The bug is really strange and fixing it might not be trivial. That said a workaround exists: Enable either the SSS option or the SSR option in the render panel.
Clément Foucault (fclem) closed this task as a duplicate of T56668: Intel HD530 + Windows 10 Bugs.Oct 23 2018, 6:09 PM
Mathieu Dijkstra (x_mtd_x) added a comment.Oct 24 2018, 3:24 PM
thanks it works{F5213031}
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed Eevee.Jun 19 2020, 11:11 PM
