Windows 10
- Open default scene
- Be sure render is in New Window mode
- Press F12
- New window is created with topbar
- Press F12 several times, the topbar is offset outside of the view (reset when move the window)
I have seen that the problem is only if the window is greater than monitor size. If the output window fit in monitor, the topbar is fine always.
Example:
