Maniphest T57678
Culling of smoke depending on view direction
Closed, Resolved
Clément Foucault (fclem)
Mal Duffin (mal_cando)
Nov 7 2018, 3:56 PM
  • BF Blender: 2.8
  • EEVEE & Viewport
Philipp Oeser (lichtwerk)
Windows 10, GTX 1070
Broken: Blender 2.8 Alpha 2 7b271d5fc11
The smoke itself seems to disappear, depending on the rotation of the viewport.
  1. Load up the attached .blend file
  2. Shift A to play the smoke ( let the timeline loop, takes a few seconds, in order to build the smoke sim )
After the first timeline loop, all 4 spheres are emitting smoke, but may not look like it.
  1. Rotate the viewport to see from above the wireframe cube ( smoke domain )
You will see all 4 spheres emitting smoke.
  1. Rotate around the cube, and you'll see that the smoke disappears for some of the spheres depending on the angle of viewing.
The smoke from all 4 spheres should always be visible from all angles.
Note that the culling happens with just one sphere, having more spheres helps improve the possibility that one of them will be visible.
Revisions and Commits
rB Blender
Related Objects
Mentioned Here
T56352: Physics (parent task)
rB7b271d5fc11a: Depsgraph: Ensure dependency cycle does not clear runtime memory
Mal Duffin (mal_cando) created this task.Nov 7 2018, 3:56 PM
Mal Duffin (mal_cando) updated the task description.Nov 7 2018, 3:59 PM
Mal Duffin (mal_cando) updated the task description.Nov 7 2018, 4:21 PM
Mal Duffin (mal_cando) added a comment.Nov 7 2018, 4:27 PM
If I change the camera clip start, it has an effect on the visibility of the smoke.
Philipp Oeser (lichtwerk) assigned this task to Clément Foucault (fclem).Nov 8 2018, 11:14 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Philipp Oeser (lichtwerk) added projects: GPU / Viewport, Eevee.
Philipp Oeser (lichtwerk) added subscribers: Clément Foucault (fclem), Philipp Oeser (lichtwerk).
@Clément Foucault (fclem) : not sure about smoke in regards to T56352 (atm. smoke also doesnt appear in lookdev/rendered view/ F12 render btw.), but can confirm the display weirdness...
[I am on a nvidia 970m btw.]
Clément Foucault (fclem) added a comment.Nov 8 2018, 2:50 PM
I can confirm too. I will fix it soon.
Clément Foucault (fclem) changed the task status from Unknown Status to Resolved by committing rB6ba7345ca539: Workbench: Volumes: Fix volumetrics step length calculation.Nov 12 2018, 9:19 PM
Clément Foucault (fclem) added a commit: rB6ba7345ca539: Workbench: Volumes: Fix volumetrics step length calculation.
Mal Duffin (mal_cando) added a comment.EditedNov 12 2018, 11:52 PM
Hi Clément,
I tested with the old scene, but it had the same old issue.
However, when I create the scene from scratch it works - but if I then scale the box used for the domain ( s 10 ), then I see the same issue again.
Try these steps.
  1. New Scene
  2. With the default cube selected, open the Physics panel
  3. Select Smoke, then Domain type
  4. Shift A and add a UV Sphere
  5. In the Physics Panel, select Smoke, then Flow
  6. Reselect the Domain cube, and scale it by eg 10
Shift + SPACE and let the timeline run a complete loop, then rotate around the cube to see the issue.
Clément Foucault (fclem) added a comment.Nov 13 2018, 12:28 AM
@Mal Duffin (mal_cando) what's the build number? the buildbot are only updating around 1am. So you might have tested an old build without the fix.
Mal Duffin (mal_cando) added a comment.Nov 13 2018, 9:23 AM
I had tried to build locally, but I was getting a crash - and did indeed download the latest BuildBot build, which didn't seem to have the commit.
The crash is related to your commit ( https://lists.blender.org/pipermail/bf-blender-cvs/2018-November/116145.html ), see the call stack below ( mutex is null, the crash occurs on BLI_mutex_unlock ).
If I revert that commit and rebuild, the smoke works as expected - nice one!
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed Eevee, GPU / Viewport.Jun 19 2020, 11:10 PM
