Operating system: Windows 10 64-bit
Graphics card: nVidia GeForce GTX 980
Broken: 2.80 (sub 35), branch: blender2.8, commit date: 2018-11-30 22:29, hash: 0f5b53ba4dc, type: Release
build date: 30/11/2018, 17:16
Worked: Latest 2.79
When using "view" as the transform orientation, tool widgets in the 3D View stay locked and do not track as the view is rotated around the selected object.
- Launch default Blender with factory defaults
- Select the cube
- Set the transform orientation to "view"
- Engage the transform tool. You'll see the widget properly displayed at the cube's center point.
- Rotate your view using middle mouse. Notice the transform widget does not track with the view as it rotates, but instead remains locked in previous orientation.
- If you grab a tranform widget handle and move it, the widget will snap to facing the viewer properly once the handle is let go.
- In previous versions, this widget would always remain facing the viewer when orbiting using middle mouse.
