Maniphest T58576
Alembic Normal Map Crash
Closed, Duplicate
None
Noah Catan (nncatan)
Dec 3 2018, 3:08 AM
  • BF Blender
Jacques Lucke (JacquesLucke)
Philipp Oeser (lichtwerk)
Sergey Sharybin (sergey)
Operating system: Windows 10
Graphics card: GTX1060
Broken: 2.80, cf18eb2de39, blender2.8, 2018-12-02
Blender crashes when trying to plug in a normal map into material. The object is an alembic import with animation, created in maya
From Default Startup:
  1. import alembic data
  2. create material
  3. import diffuse image texture and plug into base color of principled bsdf node
  4. import normal map image texture and plug it into a normal map node.
  5. plug normal from normal map node into normal from pincipled bsdf node.
  6. set UV Map to "uv"
  7. Crash
From Blend File:
  1. plug normal from normal map node into normal from pincipled bsdf node.
  2. set UV Map to "uv"
  3. Crash
blend file
Related Objects
Mentioned Here
rBf880b603537e: Depsgraph: Add missing cache file handling in build_id()
T56545: Normal map node with named UV map crashes material preview
rBcf18eb2de39f: Fix T56996: MacOS: Lagging when rotating the view
Noah Catan (nncatan) created this task.Dec 3 2018, 3:08 AM
Noah Catan (nncatan) updated the task description.
Noah Catan (nncatan) updated the task description.Dec 3 2018, 3:11 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Dec 3 2018, 1:53 PM
Jacques Lucke (JacquesLucke) added subscribers: Sergey Sharybin (sergey), Jacques Lucke (JacquesLucke).
I can reproduce the crash.
@Sergey Sharybin (sergey): When opening the file with asserts enabled, it crashes in DepsgraphNodeBuilder::build_id because ID_CF is not handled.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 3 2018, 2:17 PM
Pretty sure this is a duplicate of T56545?
For the unhandled ID_CF cachefile we might need a separate report?
Sergey Sharybin (sergey) added a comment.Dec 3 2018, 4:06 PM
No need for a separate report, fixed that in rBf880b603537.
The initial issue i did not look into.
Philipp Oeser (lichtwerk) closed this task as a duplicate of T56545: Normal map node with named UV map crashes material preview.Jan 7 2019, 9:24 AM
