Maniphest T58722
Crash while trying to replace materials in the material slot
Closed, Duplicate
None
Martin Harth (mhcall)
Dec 4 2018, 4:54 PM
  • BF Blender
Martin Capitanio (capnm)
Philipp Oeser (lichtwerk)
Sebastian Parborg (zeddb)
Operating system: Windows 10 64 Bit
Graphics card: 2 x GeFcorce GTX Titan X
Blender-2.80-a205493426b-win64 (2018-12-03)
Based on the default startup or an attached .blend file
I have a relative complex object with several mateirals applied, with each mateiral assigned to a defined vertex Group, If I want to replace one specific material with another material (from within the "blender internal material stock"), blender crashes immediately, no matter whether with PBR shader materials or simple materials.
Related Objects
Mentioned Here
rB6015a03255af: Cleanup: naming for return args
T56545: Normal map node with named UV map crashes material preview
Martin Harth (mhcall) created this task.Dec 4 2018, 4:54 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Dec 5 2018, 10:51 AM
Please share your blendfile here, so we can reproduce...
(this could be caused by a NormalMap node [see T56545], then this report would be a duplicate, but it is hard to tell without having access to your file...)
Marking as incomplete until this is provided...
Martin Harth (mhcall) added a comment.Dec 5 2018, 5:58 PM
Thank you, Philipp!
I have added the zipped blender file.
When saving the file, I left the astronaut's cloth in edit mode with some faces selected, in order to apply an additional material to these faces.
As soon as I am clicking into the material slot... boum, crash.
No idea, what's that...
Bastien Montagne (mont29) raised the priority of this task from 30 to 90.Dec 13 2018, 11:07 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jan 4 2019, 5:46 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
I can not reproduce the crash with a build from today. Could you see if this problem still happens for you with a recent build?
Martin Capitanio (capnm) added a subscriber: Martin Capitanio (capnm).Jan 7 2019, 8:08 AM
I can reproduce the crash with rB6015a03255af. It's a duplicate of T56545.
Philipp Oeser (lichtwerk) added a comment.Jan 7 2019, 9:22 AM
@Martin Capitanio (capnm) : thx for checking, will merge the reports then...
Philipp Oeser (lichtwerk) closed this task as a duplicate of T56545: Normal map node with named UV map crashes material preview.Jan 7 2019, 9:23 AM
