Operating system: Windows 10
Graphics card: Nvidia 980 Ti
Broken: 2.80, 497a9ef7a39, 2018-12-07
The alpha section in the header section of the node editor theme settings has no effect. Other color setting such as value work, but alpha has no effect.
This problem is apparent when opening up a fresh blender scene with no saving, so including a blend file is unnecesary.
- Open blender 2.80 beta
- Open shader editor window
- Open preferences
- Go to theme panel of preferences
- Go to node editor section of theme panel
- Click color bar of "header" under theme space settings section
- Move alpha slider
Also, this issue of sliders having no effect is present in other settings in the theme settings, for example the outline width slider under the 3D view also has no effect.
