Maniphest T59185
Quick Explode is broken in 2.8
Closed, Resolved
Philipp Oeser (lichtwerk)
Henry Schreiner (henryschreiner)
Dec 11 2018, 2:16 PM
  • BF Blender
Jacco Steur (jaccosteur)
Kelly (kiwiwikikwi)
Paul Higgins (higgoman)
Operating system: macOS
Graphics card: Something from Intel.
Broken: 2.80 e4153946ad1e81c697b8d51d92a3e2f088d0af4d, blender2.8, 2018-12-11
Open Blender, press F3, type quick explode, then press enter. Python error about name being required.
Solution
The following change in release/scripts/startup/bl_operators/object_quick_effects.py fixes the initial error:
             if self.fade:
                 explode.show_dead = False
-                uv = obj.data.uv_layers.new("Explode fade")
+                uv = obj.data.uv_layers.new(name="Explode fade")
                 explode.particle_uv = uv.name
But, then there are material errors; the old addon changed the old-style materials. Lines like this:
mat.use_transparency = True
mat.use_transparent_shadows = True
mat.alpha = 0.0
mat.specular_alpha = 0.0
I'm not familiar enough with the new materials in Python to fix that.
PS: macOS 2.8 build was outdated, so using my own build.
Revisions and Commits
rB Blender
D4181
Related Objects
Mentioned Here
rBe4153946ad1e: Fix T59005: no FCurve cleanup in the Timeline
Henry Schreiner (henryschreiner) created this task.Dec 11 2018, 2:16 PM
Philipp Oeser (lichtwerk) claimed this task.Dec 11 2018, 2:29 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Confirmed, will have a look...
Philipp Oeser (lichtwerk) added a subscriber: Jacco Steur (jaccosteur).
Philipp Oeser (lichtwerk) added a subscriber: Paul Higgins (higgoman).
Philipp Oeser (lichtwerk) added a revision: D4181: Fix T59185.Jan 8 2019, 1:24 PM
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved by committing rB54985ab5f569: Quick Explode: replace BI based material handling (using 'fade'/'blend').Jan 8 2019, 3:37 PM
Philipp Oeser (lichtwerk) added a commit: rB54985ab5f569: Quick Explode: replace BI based material handling (using 'fade'/'blend').
Kelly (kiwiwikikwi) added a subscriber: Kelly (kiwiwikikwi).Apr 7 2019, 9:27 AM
Is still broken in the windows version? I keep getting a traceback about BSDF missing
