Maniphest T59226
Cycles Displacement node not automatically inserted in older files
Closed, Duplicate
Brecht Van Lommel (brecht)
david (dasmitty101)
Dec 12 2018, 3:39 AM
  • BF Blender
  • Cycles
david (dasmitty101)
Philipp Oeser (lichtwerk)
I am having an issue with 2.80-ff108aac631-win64 2018-12- 11
I have a testing model that I created in 2.5 and imported into 2.8. when looking at it in the vie{F5927217}
{F5927215}wport shading modes as well as the rendering it works correctly in eevvee, but when I switch to cycles, parts of the model go crazy. I am uploading images as well as the file
System Information win 10 64
Operating system:
Graphics card: quadro
Blender Version 2.80-ff108aac631-win64
When using cycles rendering in solid, wire, and texture window draws the objects correctly, when switching to rendered draw type or when rendering the object does not render in the correct location.
david (dasmitty101) created this task.Dec 12 2018, 3:39 AM
Philipp Oeser (lichtwerk) assigned this task to Brecht Van Lommel (brecht).Dec 13 2018, 2:36 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.
Philipp Oeser (lichtwerk) added subscribers: Brecht Van Lommel (brecht), Philipp Oeser (lichtwerk).
This is because the tire.001 material is using displacement (directly from an image/color).
In newer blender versions this needs to go through the (new) dedicated Displacement node.
This is usually inserted for you automatically, the cycles addon runs a bit of code when it sees an older file
if bpy.data.version <= (2, 79, 1) or (bpy.data.version >= (2, 80, 0) and bpy.data.version <= (2, 80, 3)):
    displacement_nodes_insert()
This runs after the normal blender do_versions
bpy.app.handlers.version_update.append(version_update.do_versions)
Not exactly sure why this has not happened in your case (it is not clear what you exactly did when you say "imported into 2.8"... appended? opened the file?).
@Brecht Van Lommel (brecht): do bpy.app.handlers.version_update also run when appending?
I remember a similar issue in T54504 (where this apparently does not run when linking...)
@david (dasmitty101): That all being said, you can easily get around it by manually inserting the Displacement node (that takes the image as input and then goes to the Material Displacement input socket...)
Leaving this open for the time being (so we can get the question answered whether or not the cycles addon do_versions can be improved upon...)
Philipp Oeser (lichtwerk) added a project: Cycles.
Philipp Oeser (lichtwerk) renamed this task from cycles object displays incorrectly with blender-2.80-ff108aac631-win64 to Cycles Displacement node not automatically inserted in older files.Dec 13 2018, 2:38 PM
