Maniphest T59592
Multi-object editing, wrong selection priority
Closed, Duplicate
None
Lucas Boutrot (thornydre)
Dec 18 2018, 11:40 PM
  • BF Blender
Brecht Van Lommel (brecht)
Habib Gahbiche (zazizizou)
Jacques Lucke (JacquesLucke)
Operating system: Windows 10, Intel Core i7
Graphics card: Nvidia GeFroce GTX1060
Broken: 2.80, 61a816e8ff0, blender2.8, 2018-12-18
When multiple objects are in edit mode, it is hard to select a component of the object in the front, this doesn't happen when the object are joined.
  • Select two objects
  • Tab into edit mode, edge mode for example
  • Make it so one object is in front of the other one
  • Try to select an edge by clicking on a face
This should have the same effect than when one object is in edit mode, selecting one of the edges around the face. But it often select an edge of the other object.
Related Objects
Mentioned Here
rB61a816e8ff06: GP: Add calculation of center for transformation by stroke (WIP)
Lucas Boutrot (thornydre) created this task.Dec 18 2018, 11:40 PM
Habib Gahbiche (zazizizou) added a subscriber: Habib Gahbiche (zazizizou).Dec 19 2018, 12:15 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Dec 19 2018, 11:47 AM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
Could you prepare a simple .blend file that shows the problem? Would be good if I could just open the file, click at one specific point, and the result is not as one would expect. Thanks.
Lucas Boutrot (thornydre) added a comment.Dec 19 2018, 11:43 PM
I did a small blend file, you have to try to select one edge by clicking on the blue face from the camera view, it is not that easy. I did another camera with the two objects joined, and it is way easier to select an edge by clicking anywhere on the blue face.
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Jan 15 2019, 12:12 PM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Jan 15 2019, 12:17 PM
Jacques Lucke (JacquesLucke) added a subscriber: Brecht Van Lommel (brecht).
ok, I see the problem. The selection does not really behave as expected sometimes. It selects edges in the back that are not visible from view. Also it often takes many clicks until the edge in the front is selected again.
Lucas Boutrot (thornydre) added a comment.Mar 19 2019, 12:28 AM
Hey, I tried this file again, and I get a crash after a few selections (just 10 or 20 rapid random clicks on the blue face).
Campbell Barton (campbellbarton) closed this task as a duplicate of T54686: Multi-Object-Mode: EditMesh GL selection objects don't occlude eachother.Apr 30 2019, 1:36 AM
