Maniphest T59732
It's impossible to delete a Ruler
Closed, Resolved
Augusto Cezar (hilth)
Dec 21 2018, 6:26 PM
  • BF Blender
Casey Frost (HardRoosterLabs)
Francisco Prado Rodrigues (franciscoprado)
Jacques Lucke (JacquesLucke)
juan carlos aristizabal (juanc.aristizabal)
Konrad (Czteryk)
Larry Nestor (larryn46)
1 More Subscribers
Operating system: Windows 10
Graphics card: Gtx 750ti
Beta 2.80 (12/21/2018)
Broken:
blender-2.80.0-git.c9df453ce70b
After adding a rule on the 3d viewport it's impossible to delete it.
A date back was simple to delete the rule by click in it ends. Now there is no button delete the rulers.
I don't know if it is a bug or a missing feature, but it was working some weeks ago on the alpha builds.
Related Objects
Mentioned Here
T59860: Tool Pane - Measure won't go away
T60299: Ruler & Protractor does not exclude a measure
rBc9df453ce70b: Update for moving blender2.8 to master.
Augusto Cezar (hilth) created this task.Dec 21 2018, 6:26 PM
Sebastian Parborg (zeddb) assigned this task to Campbell Barton (campbellbarton).Dec 21 2018, 6:56 PM
Casey Frost (HardRoosterLabs) added a subscriber: Casey Frost (HardRoosterLabs).Jan 2 2019, 3:04 AM
I'm currently using the build from Dec 28th, can confirm this issue. I thought it was something I was doing wrong, made a post about it on blenderartists;
Blender Artists Post
Picking the end of the ruler and dragging it off the screen does delete it, as someone in the thread suggested, this however isn't consistent with the manual. One or the other could use an update.
Konrad (Czteryk) added a subscriber: Konrad (Czteryk).Jan 6 2019, 1:31 AM
Konrad (Czteryk) added a comment.Jan 6 2019, 1:37 AM
Hello.
Still not chance to delete the ruler -
Blender 2.8 2019-01-04 21:18 a77b63c56943
win 7 64bit: gforce nvidia gt 730
Regards
Konrad (Czteryk) added a comment.Jan 6 2019, 1:49 AM
Sorry for trouble I have found resolution very fast.
On menu Annotations (under N key) there shows 'Ruler" Layer.
Only enough is to click on minus button and go out from Measure option.
When you come back, you can see so there is there is nothing left.
Regards
Jacques Lucke (JacquesLucke) added subscribers: William Reynish (billreynish), Jacques Lucke (JacquesLucke).Jan 14 2019, 5:43 PM
I agree that this is very confusing. I would not expect to have to go to the Annotations panel to remove rulers + there are probably some updates missing.
Is this really how it should work, @William Reynish (billreynish) ?
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Jan 14 2019, 6:36 PM
These can be removed by dragging them outside the view (as can be seen in the tooltip as well)
Same as T60299, T59860
Will close this [since this is working as expected]
William Reynish (billreynish) added a comment.EditedJan 14 2019, 6:55 PM
I think we can make this a lot easier. In the top bar, we could have an enum with options to add, remove or move rulers.
juan carlos aristizabal (juanc.aristizabal) added a subscriber: juan carlos aristizabal (juanc.aristizabal).Feb 9 2019, 4:29 AM
i had the same problem, i solve it dragging the ruler out of the window.
I hope that it would be useful to someone :)
Francisco Prado Rodrigues (franciscoprado) added a subscriber: Francisco Prado Rodrigues (franciscoprado).Feb 26 2019, 2:21 PM
This problem seems to occur again with the most new releases. I can't remove the rulers dragging them out of the window, as I done before. The ruler stays in the viewport, even deleting it. It comes back.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Feb 26 2019, 2:47 PM
The method changed, check the tooltip.
Francisco Prado Rodrigues (franciscoprado) added a comment.Mar 1 2019, 5:31 PM
The problem persists. I delete the ruler pressing X and, after a moment its comes back. Deleting and saving the file, and then reopening, the ruler comes back, too. And the ruler was not created by me.
Larry Nestor (larryn46) added a subscriber: Larry Nestor (larryn46).Dec 29 2020, 1:54 AM
Maybe it is fixed now. To turn off a measure, left click on the measure end point to select it, then x to delete it. I'm using Blender 2.9.1.0
