Maniphest T59837
Dupliverts don't work when a modifier is added to duplicator object
Closed, Duplicate
Brecht Van Lommel (brecht)
Finn Bear (finnb)
Dec 25 2018, 5:32 AM
  • BF Blender
  • Cycles
Finn Bear (finnb)
Tokens
"Mountain of Wealth" token, awarded by finnb.
Operating system: Ubuntu 18.04
Graphics card: Nvidia 1080 Ti
Broken: Blender 2.80 (6d89337257b6 from December 25)
The cycles viewport won't stop udpating itself when a dupliverts parent object has a mirror modifier (or some other modifiers) applied to it. By "won't stop updating," I mean that it continuously renders sample 1 out of n. In my experience, this also stops the dupliverts from rendering in F12 cycles render.
  1. Create a plane
  2. Enter edit mode on the plain
  3. Select all vertices
  4. Drag all vertices down, away from the origin
  5. Add but do not apply a mirror modifier in the Z direction
  6. Create a cube (as a separate object, so enter object mode first)
  7. Make the cube a child object of the plane
  8. Enable dupliverts on the plane
  9. Enter cycles render mode
  10. Enter rendered mode in viewport
Workaround
  1. Apply the mirror modifier
Related Objects
Mentioned Here
rB6d89337257b6: Fix/cleanup typos and such in UI messages (and some comments).
Finn Bear (finnb) created this task.Dec 25 2018, 5:32 AM
Finn Bear (finnb) updated the task description.Dec 25 2018, 5:34 AM
Finn Bear (finnb) awarded a token.Dec 25 2018, 5:38 AM
Finn Bear (finnb) updated the task description.Dec 25 2018, 5:40 AM
Brecht Van Lommel (brecht) claimed this task.Jan 4 2019, 2:11 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 50.
Brecht Van Lommel (brecht) edited projects, added BF Blender, Cycles; removed BF Blender: 2.8.
