Maniphest T59995
Mantaflow Review
Closed, ResolvedPATCH
Aaron Carlisle (Blendify)
Bastien Montagne (mont29)
Dec 30 2018, 10:06 PM
  • Physics
  • BF Blender (2.82)
  • Tracker Curfew
15ewolsey@gmail.com (Enoch11223344)
Alistair Sealy (alisealy)
AR (arc4g)
Brecht Van Lommel (brecht)
Conrad Dueck (getrad)
21 More Subscribers
Tokens
"Like" token, awarded by erickblender."Party Time" token, awarded by HARDNAX."Love" token, awarded by jbaker8935."Love" token, awarded by bblanimation."Love" token, awarded by Kramon."Love" token, awarded by furby."Love" token, awarded by eversimo."Love" token, awarded by tobkum."100" token, awarded by Frozen_Death_Knight."Love" token, awarded by ofuscado."Love" token, awarded by xrg."Love" token, awarded by Dabi."Love" token, awarded by PiloeGAO."Love" token, awarded by Xlindvain."Love" token, awarded by mistajuliax."Love" token, awarded by Enoch11223344."Like" token, awarded by cgndev."Love" token, awarded by HenriB."Love" token, awarded by brilliant_ape."Like" token, awarded by mantissa."Burninate" token, awarded by gottfried."Love" token, awarded by bnzs."Like" token, awarded by Schamph.
Since Mantaflow project review itself is split in over ten patches, think it's worth having a general task to link them all, and also to manage general requests and discussion.
Detailed review is to happen in relevant differentials.
Related Objects
Mentioned In
rCdd54bf816d45: Mantaflow [Part 6]: Updates in /blender/source
rB043cac5d20e2: Mantaflow [Part 12]: Updated docs
rBceba74dcd7bb: Mantaflow [Part 8]: Customization for particle system
rB7bd3d2be0807: Mantaflow [Part 5]: Update other /intern packages
rBd27ccf990c2b: Mantaflow [Part 6]: Updates in /blender/source
rB7b87d3d34ec5: Mantaflow [Part 11]: Updated entire smoke.c code
rBdb8726dfd53f: Mantaflow [Part 9]: Updated rna smoke code
rB829a83262f8f: Mantaflow [Part 7]: Added bake configuration
rB41fd60db16fc: Mantaflow [Part 4]: Adapted build config
rB9064655a70c6: Mantaflow [Part 10]: Updated fluid modifier settings
rB4235fe37d6aa: Mantaflow [Part 3]: Customized UI for Manta fluids
rB2aa4301c88aa: Mantaflow [Part 2]: Added fluid wrapper files
rB4ff7c5eed6b5: Mantaflow [Part 1]: Added preprocessed Mantaflow source files
T66307: Nodes & Physics Module
Mentioned Here
D3860: Mantaflow [Part 10]: Updated fluid modifier settings
D3852: Mantaflow [Part 3]: Customized UI for Manta fluids
D3858: Mantaflow [Part 9]: Updated rna smoke code
rB6b7b619f06af: Mantaflow: Cleaned up extern C in implementation file
D3861: Mantaflow [Part 11]: Updated entire smoke.c code
There are a very large number of changes, so older changes are hidden. Show Older Changes
joel heethaar (joel_nl) added a comment.Apr 18 2019, 11:16 AM
There's a pull request from David Ullmann extending the NOPYTHON option.
@David Ullmann (robocyte) Perhaps you can give some insight in regards to performance?
Nils Thuerey (n_t) added a comment.Apr 18 2019, 4:19 PM
@Brecht Van Lommel (brecht) Good question, to add to sebbas comments, there are a few reasons for the python bindings: a first mundane one is that that's how the mantaflow solver worked originally, and it would have been a lot more work to switch to C/C++ bindings. Also, the performance impact is negligible, as mantaflow provides all the solver building blocks via python, but each of the steps is quite expensive. So there are no low-level operations in python (e.g. access to grid cells), but just a small number of calls to high level functions that typically make several passes over the full grid.
And then the python bindings provide some interesting outlooks: it will make it very easy to merge any future improvements from mantaflow back into blender, and hopefully at some point also allow for very flexible simulations. E.g., users could add own scripted hooks and modifications via python into the simulation loop to change the way the simulation runs without having to recompile. In general, it makes the data flow in the simulations very flexible. In the long run, I think it would also be awesome to have a kind of node editor to set up the simulations, but that's a bit further away :)
Brecht Van Lommel (brecht) added a comment.EditedApr 18 2019, 5:00 PM
Ok. The main concern is not so much that it's slow for fluid simulation by itself, but if multiple performance sensitive areas use Python it does become a problem to have these global locks. If this is how the Mantaflow API works and it's a big burden to use C++ instead it seems acceptable.
For further customization, we should try to figure out a way to fit this into the new node system that is being designed, rather than using Python scripting. We are still trying to work out the design for these kinds of systems, but if there are specific ideas regarding Mantaflow nodes it would be interesting to see what they could look like and how they can fit in.
https://wiki.blender.org/wiki/Source/Nodes
Stephen Swaney (stiv) added a subscriber: Stephen Swaney (stiv).Apr 18 2019, 5:16 PM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).Apr 18 2019, 9:26 PM
Martin Felke (scorpion81) added a subscriber: Martin Felke (scorpion81).Apr 19 2019, 3:10 PM
Nils Thuerey (n_t) added a comment.Apr 23 2019, 1:53 PM
@Brecht Van Lommel (brecht) Okay, yes - the GIL seems to be unproblematic so far. It could make the UI somewhat unresponsive when baking large sims, though. The new node system notes look interesting. I think for mantaflow it would neat to go for the "everything-nodes" direction, where a node graph would define the data flow of the simulation. This could then use a python back-end, or directly hook into the mantaflow functions (the functions that are exposes to python are the crucial ones that ideally would also be available as nodes). It's definitely a good point to keep in mind.
Sam Van Hulle (sam_vh) added a subscriber: Sam Van Hulle (sam_vh).Apr 25 2019, 2:58 PM
Nils Thuerey (n_t) added a comment.Apr 26 2019, 12:41 PM
I have another question here for the experienced blender devs (@Brecht Van Lommel (brecht) @Sam Van Hulle (sam_vh) @Martin Felke (scorpion81) @Jacques Lucke (JacquesLucke) and maybe others?): what would be the best next steps for an official 'approval' of the mantaflow diffs? I saw the 2.8 timeline, and I guess it would be ideal to verify that the patch is in a good enough state some time soon. Then it could be merged into the main branch as soon as possible after 2.8 is released in July, such that it can be included for the 2.81 release.
We could also continue with smaller fixes on @Sebastián Barschkis (sebbas) branch on the side. These shouldn't change anything within the larger structure of the diff here, but there are a few smaller cleanup and UI fixes that would be good to address.
Silas Opel (Schamph) awarded a token.May 1 2019, 12:47 AM
Brecht Van Lommel (brecht) added a comment.May 1 2019, 11:25 AM
The plan is still for @Bastien Montagne (mont29) to do the initial code review. @Bastien Montagne (mont29), will you have time to do this in the next few weeks? Spending like one day to go over the code and testing the functionality.
Bastien Montagne (mont29) added a comment.May 1 2019, 3:54 PM
Yes, it’s still on my radar for this week or next one…
Nils Thuerey (n_t) added a comment.May 2 2019, 1:56 PM
@Brecht Van Lommel (brecht), @Bastien Montagne (mont29) - okay, very good!
Bastien Montagne (mont29) added a comment.May 2 2019, 4:32 PM
@Nils Thuerey (n_t) Hmm, looks like the branch could use a merge with master again. ;)
Bastien Montagne (mont29) added a comment.May 4 2019, 11:10 AM
Some initial usability review after using the branch for a few tests, and a first quick review of the patches:
Results looks great!
Am by no means a specialist of that area, but there is definitively a serious improvement over previous fluid/smoke sims. And I have yet to try all the advanced stuff (especially guiding…).
Usage is less 'user friendly' than with previous sims
  • You have to bake to see anything, there is no real-time preview/simulation done during play.
  • For fluids, besides the Show FLIP option which can give you an idea of the result, you even need two steps of baking to get a result (first bake the simulation, then bake geometry and/or particles from sim).
I don’t have a very strong opinion on that, it is more a topic to discuss with artists I guess. Yet I’d expect it to make the 'entry point' for beginners/casual users much higher at least… Realize this is also likely a limitation of the python binding design, this could probably not work well in a real-time context?
On the other hand, the ability to separate baking in steps can also be very useful in more production-oriented cases I think, since you save time by not having to recompute everything if you want to e.g. generate finer mesh.
And the possibility to pause and resume baking is also a nice feature.
Showstoppers
IMHO, opened to discussion, and other devs are welcome to shine in on that topic of course.
Cache Handling
If you go to Edit mode, or try to render non-first frame of the (fully baked) simulation, you lose everything and get dummy domain cube again, until you go back to first frame and 'scroll' again… This is a caching bug, which does not affect cloth simulation in same branch e.g., so think there is an issue in how mantaflow integration code handles this?
Incidentally, there is also missing feedback about cached frames in the timeline (the colored band in the cached range of frames).
No Versioning & Crash
There is no versioning done at all. This means that currently old elbeem sim remain, old smoke one is kind of badly converted to new manta (and crashes)… this should be addressed, in worst case by just nuking old sims altogether.
Trying to open a file with some old sims just crashes for me:
Misc
Am getting those messages repeatedly in the console:
  File "<string>", line 1, in <module>
  File "<string>", line 143, in bake_mesh_74
  File "<string>", line 128, in bake_mesh_process_74
NameError: name 'sm74' is not defined
Names are not fully consistent (e.g. the modifier place-holder is still called Smoke, think Fluid would be best here, since it’s the name chosen for the Physics Sims button…). This seems to also sneak in code, where sometimes smoke is used for general MantaFlow handling (in Cycles class name e.g.)…
The old fluid sim code seems to still be around, you can even still use the 'fluid' quick effect operator to set up one, though only half-exposed in the UI then… Think that one should be fully removed.
Adaptive domain is missing (marked as TODO in some areas of code), not a showstopper imho, but still a feature regression.
Code Wise
Some more detailed comments will follow in each differentials, but from general point of view:
  • Why try to re-use existing Smoke modifier code? To me it only adds confusion, makes naming fuzzy (prefix vary between defines/enums/structs/functions/etc., from old smoke to (way too) generic fluid to few cases using better manta one…). Some names are even plain old ones from smoke, that is utterly confusing.
  • Old Fluid (elbeem) sim code remains half-active, user cannot directly see/edit it but it can still be added indirectly (through quick effect e.g.), this should be cleaned up I think.
  • To me it looks like the patches have been split by some kind of logical categorization, but unless am mistaken, they are not independent (as in, I doubt much previous patches can be applied and compile without the last one (D3861)). This is fine for review, but has to be kept in mind for final commit into master (we want all commits there to build and not crash ;) ).
Bastien Montagne (mont29) added a comment.May 4 2019, 3:57 PM
Note: just updated the branch against latest master (was kinda painful, thanks to some 'cleanup' in BKE physics files :( ), would be nice if patches could be updated too.
Nils Thuerey (n_t) added a comment.May 5 2019, 3:44 PM
@Bastien Montagne (mont29) thanks for the detailed comments! We'll have to more carefully look at the points you mentioned. Good idea to make the naming scheme consistent, to properly indicate the parts of the new solver. I'd suggest using "manta" there to distinguish it from the old smoke and liquid version.
And you think it would be better to remove the elbeem and smoke solvers directly? That definitely would be a good next step. The manta code was built using the previous smoke version, hence all the similarities. The old smoke modifier should be removed though. And the liquid one as well, together with all the elbeem code...
The cache handling looks like a bug, I'll try to reproduce that. And regarding the old smoke and liquid sims, I think it would be safest and easiest to add a warning they're not supported anymore. The smoke ones potentially could be converted to some extend, but the liquid sims work quite differently now.
Conrad Dueck (getrad) added a subscriber: Conrad Dueck (getrad).May 31 2019, 5:44 PM
Grant Kim (archost) added a subscriber: Grant Kim (archost).Aug 2 2019, 5:46 AM
Dalai Felinto (dfelinto) mentioned this in T66307: Nodes & Physics Module.Aug 21 2019, 3:44 PM
B (bnzs) awarded a token.Aug 26 2019, 8:09 PM
Sebastián Barschkis (sebbas) added a revision: D5620: Mantaflow [Part 12]: Updated docs.Aug 29 2019, 1:55 PM
Sebastián Barschkis (sebbas) added a comment.Sep 2 2019, 8:57 PM
Hi everyone! Some very needed updates on the Mantaflow fluids!
Here are some changes that have been addressed (@Bastien Montagne (mont29) thanks for the detailed comments!)
  • The diffs are now ready for a clean merge. I.e. the 12 diffs could be applied one at a time without any compilation issues in the master branch. One only has to consider the new dependency order (1, 2, 3, 10, 4, 7, 9, 11, 6, 5, 8, 12). That is, [Part 2] depends on [Part 1], [Part 3] depends on [Part 2], and so on.
  • Old smoke and liquid (Elbeem) code is completely gone.
  • Names have been cleaned up. Old smoke references have been replaced with "manta".
  • Adaptive smoke domains are now supported too.
  • Minor UI cleanups.
  • Fix for caching bug.
  • Fix for versioning crash
As always, the fluid-mantaflow branch is up-to-date with the diff (and 2.81 of course). Minor fixes will always go there first and it could be merged into the diffs one last time before landing them in master.
Nils Thuerey (n_t) added a comment.Sep 3 2019, 6:41 PM
@Sebastián Barschkis (sebbas) - neat! I've tested the version in the last days. It compiles and runs nicely on my mac. I think this version is ready to be merged, as far as I can see.
Gottfried Hofmann (gottfried) added a subscriber: Gottfried Hofmann (gottfried).EditedSep 9 2019, 10:24 AM
Thanks to adaptive domain this is now feature complete compared to the old system, yay! Thank you for the hard work over all those years.
I discovered two showstopper issues:
  • Currently I cannot add modifiers after the manta mod. Many users add modifiers after fluid sims, for example to apply some controllable smoothing that does not require re-bakes.
  • The cache indication (colored lines) in the timeline is missing.
A nice to have would be a button that bakes both simulation data and mesh at the same time.
Gottfried Hofmann (gottfried) awarded a token.Sep 10 2019, 10:10 AM
Gottfried Hofmann (gottfried) added a comment.Sep 11 2019, 11:22 AM
What influence does the parameter for Real World Size have? I have created a demo file with a 10cm domain and a simple drop and the result looks like a huge splash (file is attached):
til ation (tilation) added a subscriber: til ation (tilation).Sep 13 2019, 9:51 PM
This comment was removed by til ation (tilation).
Midge Sinnaeve (mantissa) awarded a token.Sep 20 2019, 2:33 AM
Ted Nielsen (brilliant_ape) awarded a token.Sep 21 2019, 4:02 AM
Gottfried Hofmann (gottfried) added a comment.Sep 22 2019, 10:26 AM
I found another issue - here the fluid is has an offset to both the inflow and the collision object. The domain has been changed in edit mode:
Sebastián Barschkis (sebbas) added a comment.Sep 25 2019, 3:38 PM
Hi Gottfried!
The issue with the modifiers should be fixed now! The colored timeline is still a to-do, I'll look into that.
The "Real World size" is currently only being used so that viscosity values can be entered in [m^2 / sec]. Another to-do is to go through all input values and adjust them to world units where possible - taking into consideration the world size (e.g. initial velocities in m/sec).
Your last issue seems to be because of the offset of the origin. If you first apply all transformations and then set the "Origin to Geometry" it should all line up. I see the issue though, better would be to not have to worry about the location of the origin.
john baker (jbaker8935) added a subscriber: john baker (jbaker8935).Oct 5 2019, 8:25 PM
This comment was removed by john baker (jbaker8935).
Henri Burau (HenriB) added a subscriber: Henri Burau (HenriB).Oct 20 2019, 11:18 AM
Sebastián Barschkis (sebbas) edited projects, added BF Blender (2.82); removed BF Blender.Oct 22 2019, 11:00 AM
Henri Burau (HenriB) awarded a token.Oct 23 2019, 1:24 PM
Byungchul Kang (cgndev) awarded a token.Oct 24 2019, 10:49 AM
15ewolsey@gmail.com (Enoch11223344) awarded a token.Nov 2 2019, 7:42 AM
15ewolsey@gmail.com (Enoch11223344) added a subscriber: 15ewolsey@gmail.com (Enoch11223344).
Julien Leménicier (mistajuliax) awarded a token.Nov 4 2019, 9:42 PM
Julien Leménicier (mistajuliax) added a subscriber: Julien Leménicier (mistajuliax).
Sam Van Hulle (sam_vh) removed a subscriber: Sam Van Hulle (sam_vh).Nov 24 2019, 11:19 AM
Lucas Schlindwein (Xlindvain) awarded a token.Nov 25 2019, 6:16 PM
Léo Depoix (PiloeGAO) awarded a token.Nov 27 2019, 12:03 PM
Sebastián Barschkis (sebbas) added a comment.Nov 29 2019, 5:02 PM
Hi everyone,
so during the past weeks I was able to improve some more areas in the fluid-mantaflow branch. I would say these are the final bigger changes before the master merge.
Here's a quick summary:
  • Cache: Is much more user-friendly now. In addition to the modular baking system (i.e. bake the base simulation, mesh, and particles all separately), there are 2 new modes:
    • Replay: Similarly to the current smoke cache, which bakes on-the-fly during replay.
    • Final: Which just bakes the current state of the settings with a single button click.
  • Fractional Obstacles: Liquid simulations where suffering from stepping effects at inclined obstacles. The new "Fractional" option fixes this problem (it can be thought of as an "anti-aliasing" at the fluid-obstacle interface).
  • Code structure:
    • Mantaflow files have moved to extern/ and are clang-formatted (the Mantaflow updater script (also in extern/) handles this).
    • There are only Mantaflow TBB source files now (having the OMP as well gave no real advantage).
  • New options: Several parameters, that I feel are very useful for artists, have been added to the UI (e.g. FLIP ratio, timestep min/max).
  • Bug fixes: I counted a total of 16 bug fixes since the last diff.
The only feature that's still missing is the cache color indicator in the timeline. I still might be able to add it before the official release though (I am currently working on the patch for that).
The diffs have been updated too (same state as fluid-mantaflow 6b7b619f06af).
So all in all, I would say the branch is ready for master!
Dabi awarded a token.Nov 29 2019, 10:46 PM
xrg (xrg) awarded a token.Nov 29 2019, 10:59 PM
zebus3d (ofuscado) awarded a token.Nov 30 2019, 9:53 PM
zebus3d (ofuscado) added a subscriber: zebus3d (ofuscado).
Kenn Nyström (Frozen_Death_Knight) awarded a token.Dec 1 2019, 8:52 PM
AR (arc4g) added a subscriber: AR (arc4g).Dec 1 2019, 10:53 PM
Tobias Kummer (tobkum) awarded a token.Dec 2 2019, 12:11 AM
Everton Schneider (eversimo) awarded a token.Dec 3 2019, 1:43 PM
Vitor Boschi (vitorboschi) added a subscriber: Vitor Boschi (vitorboschi).Dec 3 2019, 3:30 PM
Tyler Furby (furby) awarded a token.Dec 3 2019, 8:02 PM
Tyler Furby (furby) added a subscriber: Tyler Furby (furby).
Tyler Furby (furby) added a comment.Dec 3 2019, 8:23 PM
Will this by chance bring in OpenVDB integration? According to your website, it stated OpenVDB export (still a bit experimental, though), wasn't sure if that was within the scope of your current branch that you're hoping to get approved into master. And by OpenVDB I presume you mean by the spec of OpenVDB 4.0 so engines like Arnold can directly render them and are directly importable into a DCC application such as Houdini? Also, would this entail any work on some sort of VDB import system to get VDBs imported from Houdini or some other DCC application as well?
Maciej Jutrzenka (Kramon) awarded a token.Dec 3 2019, 9:43 PM
Maciej Jutrzenka (Kramon) added a subscriber: Maciej Jutrzenka (Kramon).
Tyler Furby (furby) added a comment.EditedDec 4 2019, 4:45 AM
Well I got excited and tried out your branch, oh yeah, it's definitely working. That's your OpenVDB cache from MantaFlow rendering right within arnold, why the density channel is called density_s6 -- I don't know. But this is beautiful. Really great work so far.
Sebastián Barschkis (sebbas) added a comment.Dec 4 2019, 7:16 PM
Yes, a proper OpenVDB setup where you can import from other DCCs is planned (just not in the 1st release of Manta). For now, the OpenVDB cache option will just save each grid on its own with the name of its parent solver appended (that's why it's "density" and "_s4").
Maciej Jutrzenka (Kramon) added a comment.Dec 4 2019, 7:20 PM
can't wait when blender will be able to import openvdb files from houdini :O once this happens Blender will become a true DCC that u can use in big VFX!
Alistair Sealy (alisealy) added a subscriber: Alistair Sealy (alisealy).Dec 5 2019, 3:55 AM
Sebastián Barschkis (sebbas) raised the priority of this task from 30 to Normal.Dec 5 2019, 10:10 AM
Christopher Gearhart (bblanimation) awarded a token.Dec 6 2019, 11:10 PM
Dalai Felinto (dfelinto) added a subscriber: Dalai Felinto (dfelinto).Dec 12 2019, 3:33 PM
@Sebastián Barschkis (sebbas) +1 for mantaflow to be in master replacing the old system. Important note though, we need to document (in the release notes and the manual) what are the known issues and limitations of mantaflow.
The old system is no longer maintained. People requiring working simulations can always go back to old versions of Blender.
Sebastián Barschkis (sebbas) added a comment.Dec 13 2019, 12:15 AM
@Dalai Felinto (dfelinto) Okay, great! I will take care of the issues / limitations part.
@Sergey Sharybin (sergey) All patches are now up-to-date. The last two patches D3852 and D3858 have the changes as we discussed them earlier. That is, the renaming from manta to fluid in both DNA structs, RNA and in the Python UI files. Once those two "go green" we can land everything in master.
Sebastián Barschkis (sebbas) mentioned this in rB4ff7c5eed6b5: Mantaflow [Part 1]: Added preprocessed Mantaflow source files.Dec 16 2019, 4:27 PM
Sebastián Barschkis (sebbas) mentioned this in rB2aa4301c88aa: Mantaflow [Part 2]: Added fluid wrapper files.
Sebastián Barschkis (sebbas) mentioned this in rB4235fe37d6aa: Mantaflow [Part 3]: Customized UI for Manta fluids.Dec 16 2019, 4:30 PM
Sebastián Barschkis (sebbas) mentioned this in rB9064655a70c6: Mantaflow [Part 10]: Updated fluid modifier settings.
Sebastián Barschkis (sebbas) mentioned this in rB41fd60db16fc: Mantaflow [Part 4]: Adapted build config.Dec 16 2019, 4:32 PM
Sebastián Barschkis (sebbas) mentioned this in rB829a83262f8f: Mantaflow [Part 7]: Added bake configuration.
Sebastián Barschkis (sebbas) mentioned this in rBdb8726dfd53f: Mantaflow [Part 9]: Updated rna smoke code.Dec 16 2019, 4:35 PM
Sebastián Barschkis (sebbas) mentioned this in rB7b87d3d34ec5: Mantaflow [Part 11]: Updated entire smoke.c code.
Sebastián Barschkis (sebbas) mentioned this in rBd27ccf990c2b: Mantaflow [Part 6]: Updates in /blender/source.
Sebastián Barschkis (sebbas) mentioned this in rB7bd3d2be0807: Mantaflow [Part 5]: Update other /intern packages.Dec 16 2019, 4:38 PM
Sebastián Barschkis (sebbas) mentioned this in rBceba74dcd7bb: Mantaflow [Part 8]: Customization for particle system.
Sebastián Barschkis (sebbas) mentioned this in rB043cac5d20e2: Mantaflow [Part 12]: Updated docs.
john baker (jbaker8935) awarded a token.Dec 16 2019, 5:05 PM
[X_Z] (HARDNAX) awarded a token.Dec 16 2019, 5:12 PM
Sebastián Barschkis (sebbas) added a comment.Dec 16 2019, 7:20 PM
So the patches are now in the master branch - big thank you to the reviewers!
Here is a short summary of what I plan to do next:
  • Move run-time variables out of existing DNA structs. Was mentioned at the end of D3860.
  • Update documentation for smoke and write new documentation for the liquid simulation system
  • Explain limitations / current issues of the solver in the Wiki. Some of them will also be marked as ToDo for 2.82 and receive higher priority.
  • Take care of all the new fluid bugs in the bugtracker
Erick Tukuniata (erickblender) awarded a token.Dec 16 2019, 7:32 PM
Konstantins Visnevskis (kivig) added a subscriber: Konstantins Visnevskis (kivig).Dec 16 2019, 9:48 PM
Dalai Felinto (dfelinto) removed Sebastián Barschkis (sebbas) as the assignee of this task.Dec 23 2019, 4:42 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Dalai Felinto (dfelinto) added a subscriber: Sebastián Barschkis (sebbas).
Aaron Carlisle (Blendify) closed this task as Resolved.Dec 28 2019, 8:24 PM
Aaron Carlisle (Blendify) claimed this task.
Aaron Carlisle (Blendify) added a subscriber: Aaron Carlisle (Blendify).
Hi thank you for submitting a patch, unfortunately, we no longer use the task subtype "Patch" please submit new patches through the differential tool: https://developer.blender.org/differential/
Nathan Letwory (jesterking) mentioned this in rCdd54bf816d45: Mantaflow [Part 6]: Updates in /blender/source.Jan 13 2020, 11:30 PM
