Maniphest T60114
simultaneous xyz input in "Transform" -> "Dimensions" in object mode broken
Closed, Duplicate
None
Marcin Twarowski (Tvaroog)
Jan 3 2019, 1:47 PM
  • BF Blender
Win 10, GTX 1080
Blender 2.80, 2019-01-02 18:59, 11f2c65128dc
Normally with multiple input boxes one can click on the first one and then drag to select all of them. That way one can insert the same value in all of the boxes. It works for xyz boxes in "Scale" tab, but not in "Dimensions" tab. If you try to insert a new number in all xyz boxes at once, Blender will reset the "z" value to what was already in the "x" box, but will leave "y" intact.
Related Objects
Mentioned Here
rB11f2c65128dc: Fix (unreported): unpredictable crashes when it is done snap after automerge.
Marcin Twarowski (Tvaroog) created this task.Jan 3 2019, 1:47 PM
Brecht Van Lommel (brecht) closed this task as a duplicate of T54771: Change of dimensions on multiple axis does not work via N panel.Jan 3 2019, 2:02 PM
