Operating system: Windows 10 Home
Graphics card: GTX 1070 8GB
Broken: 2.80, 11f2c65128dc, 2019-01-03
Worked: 2.79b release
A rigid body simulation does not bake to completion when the frame_change_pre handler is used to create and then immediately remove a mesh data object. The simulation only bakes the first two frames and then stops.
Here is a short script that reproduces the issue:
import bpy
def frame_change_pre(scene):
new_mesh_data = bpy.data.meshes.new("mesh_name")
bpy.data.meshes.remove(new_mesh_data)
bpy.app.handlers.frame_change_pre.append(frame_change_pre)I have also reported another issue related to unexpected behavior when using the frame_change_pre handler here: T60094
I have attached a .blend file that includes the script to reproduce this issue.
To reproduce:
- Open the .blend file
- Press 'Run Script'
- Playback animation or attempt to bake the rigid body cache
To reproduce from a new .blend file:
- Add default cube as a rigid body object
- Run the script
