Maniphest T60218
keyboard shortcut / isolation mode
Closed, Archived
Jacques Lucke (JacquesLucke)
Yuri (Povert)
Jan 6 2019, 12:19 AM
  • BF Blender
Yuri (Povert)
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Yuri (Povert) created this task.Jan 6 2019, 12:19 AM
Yuri (Povert) added a comment.Jan 6 2019, 12:28 AM
Not a bug but a suggestion.
Key press reaction /
The view jumps to the center of the object.
This mode is enabled to exclude the influence of other objects.
If somewhere you can't reach hit /.
Not always the center of the object coincides with the hard-to-see place of the object.
The view jumps to the center of the object, you have to Refine the point of view, highlighting something nearby and press "."
Change this view behavior.
That view has not changed after pressing /, and did not need to re-configure.
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Archived.Jan 22 2019, 12:47 PM
Jacques Lucke (JacquesLucke) claimed this task.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
Thanks for the suggestion. Unfortunately, this is the wrong place. Only bug reports are allowed here.
