Maniphest T60228
usability test result
Closed, Duplicate
None
johnsmith (jon1980)
Jan 6 2019, 9:44 AM
  • BF Blender
Brecht Van Lommel (brecht)
johnsmith (jon1980)
Operating system: windows 10 home
Graphics card: as per hardward specs on paper-based system [so I cannot relay it to you]
wider environment information can be used such as those published on www.wikipedia.org if you are into testing rather than journalism.
Broken: the version I downloaded from your website does not match the advertised features so something is wrong with the bundling of your installation file, I suggest you revise accordingly.
I am an information analyst as well in order to work I usually ask for a mutual agreement on the matter, as I have other things to do.
(example: 2.79b release)
Exact steps for others to reproduce the error Try using the software starting from installation and try to create graphics pretending to be a newbie, and, for each time you get stuck log a new test case.
johnsmith (jon1980) created this task.Jan 6 2019, 9:44 AM
Brecht Van Lommel (brecht) updated the task description.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Like the other one, this is just not a valid bug report at all.
